20 Most Recent
GE 26938GE1 Cordless Phone Questions & Answers
900 mhz
You directed this question at me, but unfortunately I'm unable to provide you with a "real" solution at this time. FixYa has informed me that by providing you with this "solution" your question will then be made visible to other experts; hopefully one of them will be able to provide you with a real solution.It would also help if you ask a question.Thank you for using FixYa.
2nd handset doesn't work
Hi Rayfatz,
I think your problem might be that the second handset is not registered with the base station. Take the second phone out of it's cradle and place it in the base station (where the first phone is), and leave it there for 20 seconds. Place it back in it's own cradle, and it should start working. Hope this helps! Hal
Model 25942EJ3-C
Try this:
1.) Make sure the answering system is on.
2.) Press flash/answerer/call waiting button on the handset to enter answerer remote mode.
3.) Press key (8) to enter Time/Day set menu using the handset.
4.) To set the Hour, key in (00)-(12), like 08 for 8 o'clock.
5.) To set Minutes, key in (00)-(59), like 15 for 15 minutes after the hour.
6.) To set AM/PM, press the CALLER ID-VOLUME up or down buttons.
7.) To set the day of the week, press the CALLER ID-VOLUME up or down buttons.
8.) Press #PAUSE/ringer button to confirm the setting.
Hope this helps you out! Hal
I have a GE model #29893GE1-B it is connected and plugged in, but no dial tone
Remove all the phones on the system. Remove all the handset batteries. Plug in one old style corded phone to the main phone jack, it is normally the one closest to the front door. Do you have dial tone? If not, it is your Telco. If you have a dial tone, plug all the other phones in testing for a dial tone as you go.
Why is my GE washer leaking water from the right front corner?
A leak coming from the front of a front-load washer is often caused by a damaged or dirty door seal. If the door seal is cracked or loose, it will need to be replaced in order to restore a watertight seal. Always ensure all clothes pockets are empty prior to washing, as objects left in pockets can damage the door seal.
Trying to find replacement phone battery for GE model 2-9421A phone set s/n 80052268.
If you mean the long-life lithium backup battery for the corded 2-line GE 2-9421 (A indicating the sales region), that is a 3V Lithium battery. The part number 5-1923 appears to be a common CR2032 coin cell battery. These are used as backup batteries for Eraseable Programmable ROM on many devices, including computers.. One source is https://www.batteriesdirect.com/product/details/button-cell-batteries/ge/5-1923 . Any CR2032 from a reputable manufacturer will work.
I hope this helps.
