20 Most Recent GE WSM2420T Top Load Stacked Washer / Dryer Questions & Answers
The dial is rarely broken. The cycle and the times for each part of the cycle are control by the main control board. If your spin cycle isn't working it might be the control board depending on what exactly the spin cycle is doing. The boards are usually kind of expensive (about $150).
You can take the chance and buy a board from an online place like:
http://www.appliancepartspros.com/search.aspx?q=control%20board
(which gives returns if you have the wrong part).
First of all though, you should go to YouTube and type in "replacing a control board for a GE washer" and you will get plenty of troubleshooting and instructional videos to help determine which part actually is failing,and to get that repair done
Good luck
GE WSM2420T Top... | Answered on Nov 20, 2015
To fix that you would need to fit a new control board on the machine. Probably not worth the cost though.
GE WSM2420T Top... | Answered on Nov 17, 2015
Going up ward into the control panel on each side is one screw to loosen. If I remember right then the control tilts forward.
GE WSM2420T Top... | Answered on Apr 11, 2015
Is this electric? Check your circuit breaker. Turn it off then back on again.
GE WSM2420T Top... | Answered on Sep 25, 2011
Thanks for choosing FixYa and welcome to the sight. You need to make sure your drain hose is not clogged up or your hoses are not damaged. You need to check the water pump also. It may be clogged or leaking from the pump area. Make sure the tub is not cracked or damaged, causing water to run out. Your best bet is starting the washer while you are viewing the hoses and the pump. You should be able to find the leak this way.
GE WSM2420T Top... | Answered on Aug 19, 2011
It sounds like you have two different problems. First, we will look at the washer. The lid switch that is in your washer is famous for coming apart. Take a small flat head screwdriver and press on the switch. You should hear, and even feel the switch engage and disengage. Let me know what you find.
Regards, Richard
GE WSM2420T Top... | Answered on Aug 07, 2011
GE WSM2420T Top Load Stacked Washer / Dryer Logo
57 questions posted
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
GE Washing Machines
  • GE Washing Machines
Most Popular Question
when starting spin cycle will not spin
  • Washing Machines
