20 Most Recent MISC 35403 - Gel SuperGlue 3 gm Tube Questions & Answers
Adhesive remove
6/23/2015 5:52:44 PM • MISC 35403 - Gel... • Answered on Jun 23, 2015
How to remove dried superglue from skin
6/23/2015 5:51:53 PM • MISC 35403 - Gel... • Answered on Jun 23, 2015
How to remove superglue
6/23/2015 5:46:49 PM • MISC 35403 - Gel... • Answered on Jun 23, 2015
3answers
How long to joint compounds have to sit to dry?
The time it takes for the joint compounds to dry depends on brand that your using. Generally 12 hours is enough, I like to let it dry over night.
7/10/2022 11:50:13 PM • Adhesives,... • Answered on Jul 10, 2022
How can I get a tighter vacuum on my vp540, should I set the vacuum time higher?
I have the same question as you? geometry dash
1/24/2022 8:23:43 AM • Adhesives,... • Answered on Jan 24, 2022
3answers
Do i need to apply seem tape over screw holes before applying joint compound?
no this is overkill. the seem tape is only necessary for seems, screw holes can be covered by a coat of joint compound, and sanded smooth after it dries
9/9/2021 8:47:08 AM • Adhesives,... • Answered on Sep 09, 2021
2answers
Cane repair
I would get a small can of contact cement. Follow directions( ex. coat each side to be glued with each other wait usually 5 min. and then press together.) There is also Scotch spray on adhesive that will also work.
6/19/2021 7:28:39 AM • Adhesives,... • Answered on Jun 19, 2021
Vp210 vacuum sealer. Why doesn't it seal or vacuum the air out?
why not contact the maker?
5/4/2021 11:32:25 AM • Adhesives,... • Answered on May 04, 2021
SMIPACK S560 ON DISPLAY SHOW A FAULT PROBLEM 2, I NEED TO KNOW THE SOLUTION
As this is not a camera, this may not be the best Forum to seek information regarding this item.
1/30/2021 5:56:15 PM • Adhesives,... • Answered on Jan 30, 2021
4answers
How do you soften an unopened tube of silicone
There is no effective long term way to store tubes of silicon. Even unopened tubes have a finite shelf life. I have found the most effective way to store opened tubes for medium lenght time, is to allow a bit of excess to flow over the tip, and allow it to form a plug. In a few months, this plug may extend the full length of the nozzle, but you can push this out with a piece of steel rod (from the tip end). I keep my tubes of silicone and caulking in a cool dry place. I've never tried the bucket of water method, so I don't know how successful that would be.
1/22/2021 1:43:52 PM • Adhesives,... • Answered on Jan 22, 2021
4answers
Mobile home roof
If it's a mobile home he probably has it 2-12 pitch roof I would use roll roofing instead of shingles hope this helps
3/19/2020 8:08:35 AM • Adhesives,... • Answered on Mar 19, 2020
0answers
4answers
Do I have to mix my joint compound or can I just use it stright out of the bucket?
On pre-mixed buckets, a lot of dry-wallers add just a little water and whip it up when tape and texturing. It flows of the blade better. But, if you're just repairing a few holes, dings and gouges, then no real need............unless it's really thickened up on you. If you have a partial bucket and are not going to use it for a while, you may want to flick some water on the surface and lay Saran wrap on the surface, then cap the bucket.
3/12/2018 12:51:19 AM • Adhesives,... • Answered on Mar 12, 2018
What type of glue can I use to glue a poster board to a glass window that will hold up in winter?
The best product that will not harm the poster or window is silicone caulk. There are also some crystal clear adhesives made from silicone now available.
11/19/2017 6:21:34 AM • Adhesives,... • Answered on Nov 19, 2017
tip
How to get superglue off fingers
Through necessity when nothing else was available, I found that acetone / nail polish remover dissolves or at least softens superglue. After the back of a folded tube burst, hands covered in the stuff, I tried various products. Hand soap, dishwasher, Handy Andy and Methlylated spirits have little effect. Laquer thinners also helps a bit, although acetone seems best. Pour full bottle into glass or metal container - not plastic, which will melt.. When rinsing hands in acetone, rub & scrub to remove stubborn bits still stuck. Concentrate under fingernails, where skin and nail meet. After removal, re-bottle actetone for future use. Lanolin oil in skin will also be removed, so after acetone-bath, wash well with hand soap, rinse, treat skin if required with a moisturizer cream. If your'e a guy, live with it - it'll give your hands a manly, rugged outdoor look! :)
3answers
Are Spackle and joint compounds the same thing?
They're not the same thing, spackle is used to fill in holes or indetations made from nails in drywall while joint compounds are used to join drywall panels together.
7/27/2015 5:29:32 PM • Adhesives,... • Answered on Jul 27, 2015
3answers
How many layers of joint compound should i put between two sheets of drywall?
at least 2. I would suggest to look closely after the second coat dries. if you have a smooth transition than it is fine, if not, a third thin coat should make the finished product look better
7/27/2015 5:27:34 PM • Adhesives,... • Answered on Jul 27, 2015
How to fast cure gorilla glue
6/23/2015 5:32:23 PM • Adhesives,... • Answered on Jun 23, 2015
MISC 35403 - Gel SuperGlue 3 gm Tube Logo
4 questions posted
Top MISC Adhesives, Coatings & Sealants Experts
Greg Bjorn
Greg Bjorn
ADMIN Andrew
ADMIN Andrew
Are you a MISC Adhesive, Coating and Sealant Expert? Answer questions, earn points and help others
View Most Popular
  • MISC Adhesives, Coatings & Sealants
Most Popular Question
remove superglue
  • Adhesives, Coatings & Sealants
