20 Most Recent
GE DBSR453EBWW Electric Dryer Questions & Answers
How do I replace heating coils
Most GE models goes like this....
Remove top cover.
Remove front door panel
Remove belt.
Remove drum cyinder.
You will see the heating element.
Automatic timer does not advance but timed heat does advance .?
Unplug the unit from the power, or shut off the breaker. Open the unit and check that all wires are firmly connected, no loose ends or broken wires. If all connects seem tight and the wires are in good condition You may need to replace the timer switch. The link below is for the users/owners manual for your machine:
http://www.manualslib.com/manual/251416/Ge-Dbsr453ebww.html
Ge dryer squeaks
replace the felt that the drum rides on, if you take the front panel off the dryer you will see it on the top of the panel where the drum rides. hope this helps you
Dryer not dry clothes
Looks like you may have an air flow restriction. First thing to check would be the lint screen. If that is clean, check your outside exhaust hood and make sure that the exhaust flap is not stuck closed, have excessive lint build up on the external screen (If Equipped) or, if birds are trying to build a nest in the exhaust hood opening. I see that quite often. But if that isn't the case, your duct work going between the drier and the exhaust hood is clogged and needs to be cleaned out. Hope this helps.
My dryer heats up but will not spin????
m11m2 Sorry to read about your problem, I hope this helps you out.
80% chance you belt is broken.. or worst case motor failure
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
