20 Most Recent GE Profile ASM10AA Air Conditioner Questions & Answers
0answers
Hi my GE profile Air
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
aa
9/28/2010 12:18:09 AM • GE Profile... • Answered on Sep 28, 2010
Compressor runs for short time
heatman101
9/27/2010 11:38:07 PM • GE Profile... • Answered on Sep 27, 2010
2answers
Unit will not turn on after power faiure. When
Depending on the age of the unit, you will find a reset button on the plug.
6/21/2010 2:28:29 PM • GE Profile... • Answered on Jun 21, 2010
I have a sunbeam 12000 btu window unit air
Sounds like the switch is wired wrong.
When you put the switch on fan only the compressor should not run at all, therefore their shouldn't be any cold air.
Check the switch to see if it's wired right.
8/25/2009 4:01:39 AM • GE Profile... • Answered on Aug 25, 2009
The unit is leaking water into the building. I
need to incline the unit so that it will drain out . Drop it down a bit from the back and it should be okay.
7/1/2009 10:29:47 PM • GE Profile... • Answered on Jul 01, 2009
Fan speed problem on GE 12,000 BTU window unit
A multi-speed, remote controlled, fan controller that only allows one speed would require a very smart person to repair it. Even the technicians don't repair them. They just replace them. This is going to cost you some parts.
7/25/2008 2:36:43 AM • GE Profile... • Answered on Jul 25, 2008
3answers
Air conditioner won' start
http://www.lowes.com/lowes/lkn?action=productDetail&productId=76034-1781-GET-213A&lpage=none Heres a link to a volt tester on Lowe's sight, use it or something similar to verify you have the correct voltage at your outlet (select the link by holding down lft mouse bttn and sliding curser to the end of address then rt click it and select copy hen rt click the fixy address up top and paste the new address in its place.-.fyi).
6/12/2008 12:58:45 AM • GE Profile... • Answered on Jun 12, 2008
2answers
GE window air conditioner showing error code E8
Shery ck here... https://www.youtube.com/watch?v=K_WWBNEuSnU also clean the unit... unplug.. spray hose thru the vanes/coils outside/back side to remove dust and dirt from the unit. Let sit for 15-20 minutes before pluging back in. https://www.youtube.com/results?search_query=clean+window+ac+unit+without+removing Best to you.
12/18/2023 5:17:56 AM • GE Heating &... • Answered on Dec 18, 2023
GE SV850 range hood stopped working
Transformers do usually feel warm. If it is very hot it has likely failed internally. Check for output voltages with a digital multimeter.
7/2/2023 11:28:19 PM • GE Heating &... • Answered on Jul 02, 2023
I have GE gas oven, getting error code F97
Impossible to say. There are a lot of variables here. Which country, and which model. Even different cities would charge different prices. It is a gas appliance, so you can't work on it yourself. Just for information, we are Fixya dot com, we aren't GE, we don't do pricing for them. The only way is to ask a local appliance shop. A good way is to ask for a recommendation on a local Facebook group where you live.
5/13/2023 3:09:56 AM • GE Heating &... • Answered on May 13, 2023
I have a GE remote control universal remote and it is number 24922cl57252 and I want to pair that with my air conditioner which is a solace air portable air conditioner and heater how do I do it
Here are the steps to program your GE universal remote (model number 24922cl57252) to work with your Solace Air portable air conditioner:
  1. Turn on your Solace Air portable air conditioner.
  2. Press and hold the "Setup" button on your GE universal remote until the red indicator light stays on.
  3. Enter the code "991" using the number buttons on your GE remote. The red indicator light will turn off.
  4. Press the "Power" button on the GE remote.
  5. Press the "Up" or "Down" button to try and turn the air conditioner off. If the air conditioner turns off, press the "Setup" button to lock in the code.
If the air conditioner does not turn off, repeat steps 2-5 with a different code from the list below until the air conditioner turns off: Solace Air Portable Air Conditioner Codes: 0277, 0363, 0364, 0365, 0403, 0454, 0455, 0456, 0457, 0474, 0475, 0494, 0495, 0496, 0497 I hope this helps!
2/24/2023 10:26:45 PM • GE Heating &... • Answered on Feb 24, 2023
PTAC Blows Cold Air in Heating Mode when it reaches -3F less than the Set Value on the Thermostat - Model: AZ65H15DABW6
It sounds like your PTAC (packaged terminal air conditioner) unit is malfunctioning. When the thermostat is set to heating mode, the PTAC should be blowing warm air, not cold air. There are a few possible causes for this issue:
  1. The PTAC may be low on refrigerant. If the unit is low on refrigerant, it may not be able to properly heat the air.
  2. The PTAC's reversing valve may be stuck in the cooling position. The reversing valve is responsible for switching the flow of refrigerant between heating and cooling mode. If it is stuck in the cooling position, the PTAC will blow cold air even when the thermostat is set to heating mode.
  3. The PTAC's heating element may be malfunctioning. If the heating element is not functioning properly, the PTAC will not be able to heat the air.
I recommend contacting a trained HVAC technician to diagnose and fix the issue with your PTAC. They will be able to determine the cause of the problem and repair it properly.
1/6/2023 8:23:16 PM • GE Heating &... • Answered on Jan 06, 2023
PTAC fan stalls when heat pump stops
Sounds like a bad motor module.
12/11/2022 3:01:46 AM • GE Heating &... • Answered on Dec 11, 2022
Why won't the heater of ge zoneline 2100 stay on
Hi, If the heater goes off right away when you start it, please check the corresponding fuse within your fusebox. Also, checking for any warn wires would be good as well. I would also test other outlets verify that it's not your current power source that's the issue. Thank you.
11/3/2022 12:49:49 AM • GE Heating &... • Answered on Nov 03, 2022
GE Profile ASM10AA Air Conditioner Logo
15 questions posted
Top GE Heating & Cooling Experts
vince
Alfredo Texmenistan
Level 1 Expert
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • GE Heating & Cooling
Most Popular Question
compressor runs short time
  • Heating & Cooling
