20 Most Recent
NEC IT3510 Copier Questions & Answers
The imaging unit need to be changed but it was
When a new Imaging Unit is installed there is a fuse contained within the new unit that blows and resets an electronic counter in the machine. If you installed or had installed a new imaging unit, then the only way the machine would be asking for a new imaging unit now is if either you ran about 70,000 copies or somehow the new unit did not reset the counter. I have never heard of one not resetting the counter as at the same time the counter is reset, the machine initializes the new unit and adjust the ATDC ratio. If this had not occured the mixture of toner to starter (developer) would not be correct and the copies would either become light (undertoned) or have a dark background (overtoned).
If you had the new unit installed then I would contact the service company that installed it and ask for a replacment. If you installed it yourself then there may not be much you can do. You can order a new reset fuse for around $5 and replace the fuse in your imaging unit so the machine thinks there has been another unit installed. precisionroller.com has them. Just go there and enter "Di350 fuse" in the search box. In case you were not aware, Your NEC is made by Minolta and is indenticle to a Di350/351.
Those would be your options.
Good Luck and Thank You for using Fixya.
WheatlandServices
12/17/2010 10:44:00 PM •
NEC IT3510...
Answered
on Dec 17, 2010
Where is the drum unit
Open the large door on the right side of the copier. The drum or more correctly called the Imaging Unit sits right there in the middle of the machine. It is the unit with the 2 colored "hook" like handles on it. Use these to pull the unit straight out. These can be "reset" so you can usually get double life out of them in case your "Replace Imaging Unit" indicator is on.
NEC IT 3510 starts with
www.user-guides.co.uk/.../nokiareset/nokia-reset-software-3510-pdf.html
you can copy and paste this link in your internet address bar under a new tab. It will bring you to a reset software download for your phone. you can reset phone to default original settings. there are also other sites for updating your software if you ever need to as well.
WHAT DOES THE CODE COBOA MEAN?
It is the elevator malfunction.For reset press the trouble reset switch on the tech.rep.setting switches board or open and close the front door or turn OFF and ON the main switch.
C0500
Fuser unit problem,check,clean or change the heater lamps,thermistors and thermofuses.
NEC projector M322X indicates light but cannot turn on
Based on the information provided, it is possible that there may be an issue with the projector's power button or internal components. It is recommended to try the following troubleshooting steps:
1. Check the power source: Ensure that the projector is properly plugged into a working power outlet and that the outlet itself is functioning correctly.
2. Reset the projector: Some projectors have a reset button or option in the settings menu. Try resetting the projector to see if this resolves the issue.
3. Check for internal issues: If the above steps do not work, there may be an issue with the projector's internal components. It is recommended to contact a professional technician or the manufacturer for further assistance.
In summary, if a NEC projector indicates light when plugged into a power source but does not turn on when the power button is pressed, it may be due to issues with the power source, internal components, or other factors. Troubleshooting steps such as checking the power source and resetting the projector may help resolve the issue, but professional assistance may be required if these steps do not work.
