20 Most Recent
Canon imageRUNNER 3030 Black and White Copier Questions & Answers
Error code E000000-0001
Hello nelco9,I can help you clear the code easy enough. But there is a strong probability the code will come back almost immedietly.Copiers use high heat and pressure to bond the toner to the paper.It is of course critical to accurately monitor this high temp as to insure against fire.The code E0000000-001 means that for any number of reasons the copier did not or could not reliably monitor this temp.Now, something as simple as a momentary variation in the power to the plug the device is plugged into can cause this code as the plug voltage and/or frequency is sufficient to interfere with the copier's ability to track the temp, so lets hope for the best.Trust me there are so many fail safes involved in this process that the copier will properly shut down if the problem is serious.Ok,locate the'ADDITIONAL FUNCTIONS" button on the op panel.It is just to the right of the 9 key pad.Press it, let go, then the numbers 2&8 simaltaneously,let go, then ADDITIONAL FUNCTIONS again.You will see a new screen.Press "copier". Tabs appear at the top.Press the "function" button.New screen again.Press "clear".New screen.Press "ERR" .Press "OK" in the lower right corner.Now if you TRULY know where the main power switch is (right rear of copier about halfway down) then power the copier off.If in doubt simply unplug the copier.When you turn it back on the copier will attemt to start up as normal.If it does then congrats !!.If it fails you will need a new fusing unit which can run as high as $800. I truly hope I have helped you.Take care.
3/20/2019 9:37:04 AM •
Canon...
Answered
on Mar 20, 2019
Canon ir 3030 paper loading problem in cassette
The problem could be one of several things.
1) Check your "printer preferences" setting and make sure you have selected the CORRECT SIZE OF PAPER. For example; Letter, Legal, etc.
2) Un-install and re-install the drivers.
Hope these suggestions help.
8/2/2015 7:11:40 AM •
Canon...
Answered
on Aug 02, 2015
I have a canon ir3030 there is one side sightly dark and one side sightly light in same page i need solution?
Hi
You will probably need to replace the toner cartridge.
If you are certain it is not nearing empty, try removing the cartridge, putting in a plastic bag and giving it a little shake. Then clean the area around where the toner comes out both on the cartridge and on the printer.
That might help a little, but generally once it starts fading it means you are coming to the end of the toner/ or possibly fuser unit
You might also try changing your settings to print higher quality. That might allow you to get a few prints out a bit clearer, but will also speed up the demise of your cartridge
3/27/2015 3:21:41 PM •
Canon...
Answered
on Mar 27, 2015
Canon ir 3030 printout will be black
Verify charge corona, when you start a new copy, open lateral door when paper is in the right of drum, then look if the drum is full covered with toner.
12/6/2014 11:04:08 AM •
Canon...
Answered
on Dec 06, 2014
Cassestte does not work properly
If there is an adjustable slide that maintains the paper in a stack, make sure it is secured and not moving (the slide/guide).
11/3/2014 5:02:12 PM •
Canon...
Answered
on Nov 03, 2014
Error code e000020 04a0
the toner sensor of the developing unit detect the abcense of toner while detect toner in the hopper, posible toner obstruction between the hopper and developing unit or defective toner sensor
4/29/2014 7:14:46 PM •
Canon...
Answered
on Apr 29, 2014
