20 Most Recent
Sharp AR-M550U Copier Questions & Answers
I am having a problem f3-22 Code Is it possible to help
Hi
A quick look on the internet found several items that may be of interest. The first here:
http://olsonbros.com/sharp/support/pdf_trbl/trbl-arm550n_m550u_m620n_m620u_m700n_m700u.pdf
is a diagnostic tool in pdf format carrying all the error codes for your machine and the reason for them. In your case the "f3" refers to the paper tray lift mechanism and the "22" to tray 2. I recommend you download and save this file to disk for future reference. I tried a different site and this confirmed the error as "Paper does not lift in the tray".
Unfortunately neither of these sources was any help at all with the solution.
I did find a service manual for your machine however which I think should help you and again I suggest that you download it from here:
http://diagramasde.com/diagramas/otros/SM-ARM550APR_13_2004.pdf
and save it to disk for reference. However please be patient, very patient, it is a big document (over 50 Mb). At that size I haven't been through it to pinpoint your problem areas in it, but if you use Acrobat Reader's search facility for "f3" it will cut your reading time down !!!
There are masses of diagrams and tables to help you pinpoint the problem and the section of the machine and the parts involved.
Hope this is helpful, if so would you please register that with Fixya
Cheers
How can i get aproduct key online ?
Your request is confusing and lacking details, but I'll try....
The base model 550U has USB and parallel printing capability. Networking comes standard on the 550N but is an add-on option for the 550U in the form of a "print expansion kit" made up of a NIC, 2 flash rom that plug into the main control board, and a product key. If the area where your print ports are located has a network CAT-5 plug, it means your expansion kit is installed, your product key has somehow gotten zapped and you need to re-enter it. The model number for the kit is AR-P19. If you have the P19 box with the registration sheet, the product key may be written on it. Product keys can be obtained online but only a Sharp dealer has access, sorry.
Error Message - L4-03 What is wrong?
If you had paper jams it will display this error after 3 in a row in the fuser. Double check to make sure all paper is removed from the fuser. To reset, on the keypad press pound star clear star and enter sim 14 and press copy button. reset copier it should turn off and on, test if paper jams there may still be something stuck.
H4-00 error code
Cancel with SIM code 14. Code is for HL1 fuser lamp. the lamp could be broken but the other 2 may be able to compensate
H4 error 00
Error code is for heat-roller which has an abnormally low temperaturethe fusing unit on that machine could be dirty and the thermistor and thermostat could need cleaning to remove the paper dust ash build-up, OR the fusing unit`s halogen bulb needs replacing which is rarely the caseOR and most likely scenario is that because of a power fluctuation it enters into that error as a sort of safe-modethe error needs to be reset by a technician such as myself which is familiar with Sharp copier CROP system , a CROP 14 should clear the error if it was a power fluctuation the error should go away, if not take it to a technician (qualified preferebly)
Scaner download
http://support.sharp.net.au/drivers/, you can down load the application software,ie sharp desk from this site but while on instalation it will ask you for the original disk you have to insert the original cd and serial no if you dont have I can provide you the sr no try this, rate this and vote for this.
