20 Most Recent
Canon ImageRUNNER 3235 Black and White Copier Questions & Answers
Ir3235 canon system code E000002-0000
Solution to fix this problem
Hi. That error is related to the fixing unit. You need to clear it from service mode first.
You need to be quick doing the next process because machine will automatically turn off after a few minutes.
With the copier turned on press the next key secuence
Press adittional function
Press 2 and 8 ( at the same time )
Press additional function.
Service mode should appear in the screen . If it doesn't repeat the secuence until it does .
When service mode appears press in the touch panel COPIER
Then select FUNCTION
Then select CLEAR
then select in the lower list ERR
Then press ok in the lower corner
Turn off the machine from main Switch. Wait a few seconds and turn it on again .
Try to make some copies . If error persist there is a malfunction in the fixing heater and need to be replaced.
6/13/2018 5:54:04 AM •
Canon...
Answered
on Jun 13, 2018
I just installed a CANON
let the scan gear tool discover the scanner by pressing discover . it will automatically discover the scanner .
4/25/2018 5:53:13 AM •
Canon...
Answered
on Apr 25, 2018
Canon ir 3235 error e000196
error in communication between laser driver and dc controller,check the wiring and connectors
7/9/2015 8:17:16 PM •
Canon...
Answered
on Jul 09, 2015
How to clear code on ir 3235?
wich code?
E000, E001, E002 You can clear under service mode:
* 2 8 *
COPIER
FUNCTION
CLEAR
ERR
TURN OFF AND ON
Hope that helped
pls.rate
5/22/2014 10:43:15 AM •
Canon...
Answered
on May 22, 2014
How can i enter in service mode in imagerunner
Entering service menu is accessible by pressing (*),
then pressing 28 for some seconds,
then pressing (*).
Choose Copier in the service menu,
then options to clear.
That should get you there.
TF
10/3/2012 7:13:50 AM •
Canon...
Answered
on Oct 03, 2012
