20 Most Recent
Canon imageRUNNER iR C4080 Color Copier Questions & Answers
Canon IR C4080 - Is
Sounds like the copier is needing to have a DC Controller or MMI reset. Before doing this make sure you have printed out the current setting in P Print, Addresses ( E-mail, Faxes, etc. ), and any other items that may be stored in the copier. I can't remember all the items a " CLEAR " will wipe out but it's a good policy to have a current copy of this printed out anyway. Before doing the clear, look to make sure the settings agree with canon print settings located behind the door panel.
Good Luck.
12/13/2015 8:44:51 PM •
Canon...
Answered
on Dec 13, 2015
E00008-0001
Hi Gracefulblon,
To be bale to provide the fix and the information of the error can you please provide the make and model of the printer.
4/1/2014 10:20:17 PM •
Canon...
Answered
on Apr 01, 2014
6 3/4 envelopes in bypass
According to how many you are doing, you can tape them to a larger piece of paper.
3/29/2014 3:21:21 AM •
Canon...
Answered
on Mar 29, 2014
E000004 0205
check the info button in service mode. it will tell you all the possibilities for all ecode occurences.
Most likely a problem with your fixing drawer connector
It might reset and go away, or you may have to change connector
E004 0205 05 Title Thermistor temperature difference error Description of detection Difference of detected temperature between thermistors is bigger than the specified value. Measures 1. The connectors of the fixing main/sub thermistor (THM1-1 to 3) are physically removed (the cable is caught, or disconnected) -> replace the fixing belt unit 2. Check the rotation of the fixing motor (the connector is physically removed or disconnected) -> replace the fixing motor or the harness3. The connectors of the pressure sub thermistor (THM2, 3, 4) are physically removed (the cable is caught, or disconnected) -> replace the thermistor or the presure stay 4. Disconnection, soiled, improper location of, or faulty pressure sub thermistor -> clean the thermistor or replace it5. Faulty drawer connector -> clean the drawer connector or replace the fixing drawer cable6. Replace the DC controller PCB
Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For
Canon Printer Support
3/6/2014 9:02:45 PM •
Canon...
Answered
on Mar 06, 2014
Printing shadow
Hi Christian,
There some possibilities of this problem: drum cartridge / transfer belt / transfer is exhausted, laser scanner assy is faulty.
1/14/2014 2:19:44 PM •
Canon...
Answered
on Jan 14, 2014
