20 Most Recent
Ricoh Aficio MP 1600L Black and White Copier Questions & Answers
Error occured SC:302
Functional Problem Turn
SC:302
Charge roller current leak
Symptom: A current leak signal for the charge roller is detected.
Possible Cause:
?? Charge roller damaged
?? High voltage supply board defective
?? Poor connection of the PCU
RICOH MP 2000 ERROR OCCURED SC302
That is a charge roller current leak. A current leak signal for
the charge roller is detected. Possible cause- charge roller damaged or high voltage supply board defective. Check the charge roller first. On the drum, the rubbery roller.
Sc390
SC390: TD sensor error
- Possible causes -
· TD sensor abnormal
· Poor connection of the PCU
I have ricoh Aficio MP
Use the network scanner. It is easier for the users and is much better.
Open the browser writes the IP hosts is then just create new users with their own folder paths (previously shared of course).
If you do not have technical training i beliave it will not be easy for you to do it.
Try the chat and ask for help from a specialist. I'd like to help but still can not chat
Service manual
YOU CAN DOWNLOAD FROM JUST MANUAL .COM OR JOINT
THE RICOH FORUM IN COPYTECH.NET,IF YOU LUCKY YOU CAN DOWNLOAD THE MANUAL FREE
