20 Most Recent Sharp AR-M257 Black and White Copier Questions & Answers
Welcome to Fixya. If your encountering a Service Code U2-40 on your Sharp AR-M257 all you need to do is to reset the machine.
Press # - Interrupt - C - Interrupt then press 16 then Start or Ok key
If you have questions please let me know. Thanks for using Fixya
Sharp AR-M257... | Answered on Feb 19, 2019
enter sim 16
Sharp AR-M257... | Answered on Apr 21, 2016
Remove your DV unit and remove any foreign body on magnetic roller but be careful do not scratch it.
Sharp AR-M257... | Answered on Feb 13, 2016
Angela,
Did they replace the rollers and seperation pad/roller? They replaced the Clutch but not the rollers odd. Also might ask about having the feeder firmware checked updated. or the control board replaced.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Sharp AR-M257... | Answered on Jan 27, 2016
The default username/password is
admin ( all lower case)
Sharp ( capitol S, the rest lower case).
Hope this helps.
Sharp AR-M257... | Answered on Feb 03, 2015
F2-04 means that the IC chip on the end of the toner has been blown by the copier due to the fact that for X-period after attempting to , the copier was unable to replenish the toner level in the developer unit, there may be various problems leading to this, most common is that the gears on developer unit was stripped, or toner motor is no longer functioning, or that the magnetic sensor on the bottom of the developer unit is coated by a layer of toner of compacted developer or toner, or you used the wrong cartridge, either way , F2-04 is usually indicative of something worse than expected, my professional opinion on this one is to send it in for repairs by a qualified service technician.
Sharp AR-M257... | Answered on Nov 28, 2014
This is a low fuser temperature error.
You should be able to reset it by doing the following at the panel.
Hit Pound, star, C, Star
enter 14, then touch start
execute on the screen
the machine will reboot and the code should go away.
if the problem persists you may need some maintenance.
If you're in Houston we'd be happy to help you out.
Skelton Business Equipment Houston Copiers
Sharp AR-M257... | Answered on Aug 06, 2014
Replace main charger unit.
Sharp AR-M257... | Answered on Jun 27, 2014
Press "0 and hold
You can remove the tray by pulling it all the way at and tipping it up and to the right. Try cleaning your feed wheels with windex on a towel, never use alcohol as it will dry out your rubber parts. If you are still having problems try using static free canned air to blow off the sensors in there. Let me know if that works other wise we can try some other steps.
I’m happy to help further over the phone at https://www.6ya.com/expert/ethan_e84416e0b13809d2
Sharp AR-M257... | Answered on Apr 17, 2014
check fuser pressure roller shaft may worn out and also check how is upper roller and bushing together if they r not ok then replace them all then u may need to reset byt your key steps #*c* choose 14 press start button will reset this error and your machine will be ok this error is for fuser motor rotation abnormal because your fusing unit is tight try it and let me know
Sharp AR-M257... | Answered on Feb 26, 2014
Please log in machine with you browser with machine ip address
and user name and password is admin and Sharp and go to address book and remove anything you do not want.
Sharp AR-M257... | Answered on Jan 08, 2014
Need to change developer .
Before clearing the code please check fusing unit first,
Sharp AR-M257... | Answered on Jan 07, 2014
Sharp AR-M257 Black and White Copier Logo
82 questions posted
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
George Mclaughlin
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Office Equipment & Supplies
Most Popular Question
document feeder feed
  • Office Equipment & Supplies
