20 Most Recent Mitsubishi HC5500 LCD Projector Questions & Answers
When I turn the projector,
The problem is most likely a warped plastic housing around the color wheel. When the wheel is forced to stop, the projector will go to standby and the lights indicate a problem.
4/23/2017 8:41:34 PM • Mitsubishi... • Answered on Apr 23, 2017
Why does my Mitsubishi hc5500 projector only display a blue screen but still play sound?
The unit may need cleaning. The lamp will shut off if the air flow is blocked by dust.
12/9/2014 11:26:39 PM • Mitsubishi... • Answered on Dec 09, 2014
I have just replaced the bulb on my Mitsubishi
Still a bad lamp
11/26/2013 4:54:55 PM • Mitsubishi... • Answered on Nov 26, 2013
The easiest way is to
If it happens on other surfaces then it looks like your LCD module is damaged. It will have to be replaced.
5/8/2011 1:59:51 AM • Mitsubishi... • Answered on May 08, 2011
Mitsubishi HC 5500. While playuing the picture
Red and Green bliking with no picture means a service problem. But you might try cleaning the filters first and being sure that nothing is blocking air flow through the projector. Red status solid means replace the lamp, but that doesn't seem to be the indication.
2/10/2011 12:47:33 AM • Mitsubishi... • Answered on Feb 10, 2011
Mitsubishi P93 thermal printer. How do I fix gear lock error on it please?
This is a highly specialized piece of equipment used for printing ultrasound and medical images. Limited help in this link https://www.google.com/search?q=mitsubishi+p93+thermal+printer+gear+lock+error ..
4/18/2024 9:39:20 AM • Mitsubishi... • Answered on Apr 18, 2024
Mitsubishi CP9550DW-S Photo Kiosk error: "(the ink ribbon is not standard)"
This suggests it is a driver issue. My first thought is that your supplier has provided copies, not originals.https://www.google.com/search?q=Mitsubishi+cp9550dw-s+the+ink+ribbon+is+not+standardIt is very specialized though and not a machine used here in North America. Contact Mitsubishi Support direct...
9/12/2023 6:28:46 PM • Mitsubishi... • Answered on Sep 12, 2023
I have a Mitsubishi XD206U DLP projector. When it receives a 720p or 1080i signal The image has extreme green tint. I adjusted in the settings w no progress on fixing this. Any thoughts?
HELLO Holly ensure that the cables connecting your video source to the projector are securely plugged in and not damage .Also test the projector with different input source it trully assist you to identify if the issue is with the projector or the specific input source.
8/19/2023 5:01:30 PM • Mitsubishi... • Answered on Aug 19, 2023
HC3800 Mitsubishi color wheel model or part number?
The Mitsubishi HC3800 projector uses a color wheel with the model number VLT-HC3800LP. This is the original color wheel that is designed specifically for the HC3800 projector, and it should be able to replace the existing color wheel in your projector. It is important to use the correct color wheel for your projector to ensure optimal performance and avoid any damage to the projector. You can purchase the VLT-HC3800LP color wheel from Mitsubishi authorized resellers or from the Mitsubishi website. You can also check for other electronic resellers or online marketplaces for availability and pricing. I recommend you to confirm with the seller that the part is compatible with your specific projector model and serial number, before making the purchase. It's also important to mention that, replacing the color wheel should solve the noise issue you're experiencing. But, it's always recommended to check the projector warranty status, or if the projector is out of warranty, consult with a professional technician before attempting to replace any part of the projector.
1/18/2023 9:28:38 AM • Mitsubishi... • Answered on Jan 18, 2023
My remote for my Mitsubishi HC4000 will not turn on the projector. Changed batteries and the red light on remote flashes fast. Projector turns on manually. Thanks
that is a hard one, (difficult)
  • well battery new bad>? or weak or bad luck buys, dollar store batteries? use Alkaline.
  • batteries in backwards whole or in part?
  • too far you are clicker to projector try 6 feet as a test, 2meters.
  • a bad remote or drowned in spilled drinks, happens vast.
  • bad luck, have bad clicker (buy a spare?) remote.
  • or wrong clicker used, mixed up with others in home or pesky kids did that to dad.
  • Read the manual see what clickers it can used, mostly 1.
8/2/2022 9:58:27 PM • Mitsubishi... • Answered on Aug 02, 2022
Mitsubishi xd550u service menual
XD550U is the upgrade vision of XD500U, they are almost same, i have xd500u service manual, you can get if for reference. mitsubishi-xd550u-service-menual-c0kfjfiw1sbibxbsbum35w3k-1-0.jpg
9/8/2020 4:04:47 PM • Mitsubishi... • Answered on Sep 08, 2020
Mitsubishi HC5500 LCD Projector Logo
Popular Tags
12 questions posted
Top Mitsubishi Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Office Equipment & Supplies
Most Popular Question
when turn projector
  • Office Equipment & Supplies
