20 Most Recent
Sony VPL-EX3 LCD Projector Questions & Answers
Good Day, I have 3
The small lamp cover dimple that is supposed to activate the protection switch doesnt reach the switch if the cover is slightly curved due to age and heating.
So I put a small dob of silastic on the dimple of the lamp cover and let it set for 24 hours. Then I put the cover back into the unit and all is OK.
In your testing, make sure you are pressing the switch down manually before you power up the unit.
Then the error message is not likely to be a cover error message.
If you still get the error then I would check the integrity of the switch mechanically and electrically. Check that the connector from the switch to the pcb is OK.
Sony VPL-EX3 "Lamp cover problem", it wont switch
There is a small switch that detects when the lamp cover is securely tightened down, so that it protects the user from the high voltages, hot surfaces, excessive bright light in the eyes, and damage to the face if the lamp implodes due to old age and overuse.
so check if the switch operates when a toothpick is pushed up and down in the cavity.This model suffers this problem when the cover is slightly warped with old age.
so put a strip of folded paper between the cover plastic protusion that actuates the switch and the switch and secure the cover and see if this is all that is needed to activate the switch properly.
if it now works, you can try putting a small drop of silastic on the cover protusion and wait till it sets over several hours in order to lengthen it slightly so that it reaches the switch properly
Comme on RESET LAMP Videoprojecteur
You can reset lamp timer of VPL-EX3 by following procedure.
Connect power cord in wall socket, standby indicator will lit red.
Press following keys on projector remote.. RESET, Left arrow, Right arrow, ENTER
Lamp timer will reset.
Hope this will help.
Thanks.
How do you turn the
Pressing the On/Off Key for 10 seconds switches on and off the projector.
While on, press the menu key for 10 secods to reset it to unlock.
Have replaced the lamp in
Press the following keys on the remote control in the following order for less than five seconds each:
I have replaced the lamp
DO the following for resetting the lamp hour
1.Connect the power cord.
2.Press the following keys on the Remote Commander in the following order for less than five seconds each: RESET, Left Arrow button, Right Arrow button , ENTER.
ok
I have purchased 2 sony ex3 lcd projectors(one for
you may have to reset the lamp hour meter to get it to work, put the projector on stanby and press the remote buttons, reset - back - forward - reset, (this is the code for a vpl hs20 projector it may be slighty different for your model)
