20 Most Recent Red Defy Helmet Youth 2012 Questions & Answers
Two plates do not work
Yes. The old one is not working due to a shorted area and that effects the entire top.
12/28/2018 6:37:16 AM • Red Defy Helmet... • Answered on Dec 28, 2018
2answers
My double door firge frezeer is not icing and the
Glori,you mite need to replace your thermostat,...... the alarm button is telling u that your fridge is not cold enough, there is also probably another prob but u need to b a electrician to sort it on the top of fridge there is a panel,.. under that there is a fusible link if one blows it will need to b replaced its soldered in no job for u unless ur a electrician hope this helps
8/14/2016 11:58:06 AM • Red Defy Helmet... • Answered on Aug 14, 2016
I have a Defy Laundromaid Electrologic 1300
probably can if they are available from the service agent parts if not consider using stockings cut to size in their place
7/14/2015 7:29:04 AM • Red Defy Helmet... • Answered on Jul 14, 2015
I want to fit a new oven switch but i need the wiring diagram
trace the wires from the old one note down and do the same for the new one,
2/9/2014 12:31:35 AM • Red Defy Helmet... • Answered on Feb 09, 2014
Fridge section too warm
Locate the temperature sensor,clear everything away from sensor.
1/18/2014 8:23:03 PM • Red Defy Helmet... • Answered on Jan 18, 2014
My dishwasher's power comes on , but the unit does not allow water to be let in before the washing program can start
I had a similar problem with my dishwasher so what I did (depending on your model) was reset it the by pressing the reset buttons on the front panel. Once I did this, it defaulted back to the start of the wash cycle and worked fine.
12/31/2013 9:28:00 AM • Red Defy Helmet... • Answered on Dec 31, 2013
Defy germini thermofan switching of before reaching temp
this is an appiance.. not a vehicle, folks whos putting these in catagory...
12/31/2013 12:24:58 AM • Red Defy Helmet... • Answered on Dec 31, 2013
MANUAL FOR DS640
wrong forum , this is, cars/trucks. sorry. ah, snow boarding, what makes you think htere is a manual ? put on head, adjust strap, if dirty clean with mild soap and water. ????
11/26/2013 1:11:03 PM • Red Defy Helmet... • Answered on Nov 26, 2013
Hi all so I have a Aprilla Pegaso 650 57 plate its been stood nearly 2 years and just won't start
It has fuel injection and yours isn't working. In the 'old days' you would have just stripped, cleaned and rebuilt the carburetor. Now you need dealers with scan tool computers to diagnose and fix. The first thing to check would be the fuel pump, which supplies the pressurized fuel to the injectors. https://www.motorcyclenews.com/bike-reviews/aprilia/pegaso-650/1997/ ..
11/8/2022 6:46:13 AM • Motorsports • Answered on Nov 08, 2022
Firing order
you need to post what engine you need firing order for
11/30/2017 1:30:16 PM • Motorsports • Answered on Nov 30, 2017
Where is the lighter fuze on a vw polo
in manal that you have recived in the car should be explained what every fuse is doing.
5/31/2017 1:12:46 PM • Motorsports • Answered on May 31, 2017
I just fitted a gianelli exhaust expansion to my old Yamaha DT125 lc -87. The bike lost 20km/h with the new exhaust. It revs better and accelerates better but when I get it to 100km/h with 3rd gear at
Go to a smaller exhaust or a longer exhaust (not practical. Engines need some back pressure. That is why headers on dragsters are all of equal length.
5/30/2017 3:16:30 AM • Motorsports • Answered on May 30, 2017
7answers
Going from synthetic blend oil to a regular premium oil? Any adverse complications?
First of all let me tell you that it is a myth that you can not go back and forth between conventional oil and synthetic or in your case synthetic blend. They all mix very well together but why on earth would you not use a full synthetic in every thing? It will keep your motor so much cleaner, and last way longer, new or 150.000 miles used, does not matter. They refine the synthetic oils way way longer to get the impurities out. Other big thing [ OILTEMPERATURE AND WEAR COLD START UPS ] Exceeds and blows conventional out of the water. plus a real full synthetic you can run a lot longer just spin a new good grade filter on or change it. Me my self Ill run Walmart full synthetic in my grand prix and ROYAL PURPLE in my 2013 mustang. I think there all full synthetics are good compared to the old dirty sludge and if all the new manufactures are recommending it now its good. Do you have any motor rebuilders or trucking builders close to you? Just go look at the oil pans to compare the too . I guarantee you will be sold that day and never run conventional again.... PERIOD.
2/9/2017 12:59:28 PM • Motorsports • Answered on Feb 09, 2017
2answers
How do I found good auto repair shop at Las Vegas ?
Call around, the one that is busy is the one you want.
2/2/2017 7:10:03 PM • Motorsports • Answered on Feb 02, 2017
I would love to know if anyone knows of a trophy top from the 50's called a Jalopy and resembles a '32 ford 5 window coupe. no fenders, square hole in roof and brass plated. I broke my dad's first 1.
call around the ford veteran and modified car clubs to see what information you can get they are the most likely people that can help you
12/21/2016 11:25:32 PM • Motorsports • Answered on Dec 21, 2016
1996 Ford explorer speedometer doesn't work
coudl be the speed sensor. or trans computer
11/1/2016 1:18:24 PM • Motorsports • Answered on Nov 01, 2016
2answers
I have a 2001 volkswagen it has started losing speed after going 70 miles and hr. for about 7 miles it start to miss in the motor and my speed goes from 70 to 50 in seconds if i push the accelerator d
A flashing SES light is a misfire and can cause severe engine damage. You need to have the computer scanned and post the codes here for more help. It could just simply need a tune-up.
11/1/2016 12:40:43 PM • Motorsports • Answered on Nov 01, 2016
2answers
What is the illuminated "E" represent next to the drive indicator?
economy ?
10/23/2016 5:51:13 AM • Motorsports • Answered on Oct 23, 2016
3answers
02 toyota corolla will start but not run.longer than 5seconds
Check fuel pump pressure, fuel filter for clogged, fuel line if purged, fuel tank valve which is attached to the chassis above the fuel tank.
8/22/2016 6:45:54 PM • Motorsports • Answered on Aug 22, 2016
Red Defy Helmet Youth 2012 Logo
22 questions posted
Top Red Motorsports Experts
ADMIN Andrew
ADMIN Andrew
Drerangula Siva...
Drerangula Siva...
Level 1 Expert
Are you a Red Motorsport Expert? Answer questions, earn points and help others
View Most Popular
Red Motorsports
  • Red Motorsports
Most Popular Question
two plates not work
  • Motorsports
