20 Most Recent GE 24 in. Profile PDW8280JSS Built-in Dishwasher Questions & Answers
0answers
0answers
Ge pdw9980n20ss
Be the first to answer 4/25/2013 4:17:49 AM • GE 24 in.... • Posted on Apr 25, 2013Be the first to answer
Bought new plactic part for the latch system but canot figure out how to get the spring back in to work correctly
go and buy it www. repairclinic.com God bless you
6/20/2012 4:15:50 PM • GE 24 in.... • Answered on Jun 20, 2012
I have been trying to
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...Dishwasher SprayArms not SpinningHow to Buy ApplianceParts OnlineA bad heating element causes many problems in dishwashers...Dishwasher Problems The HeatingElement not WorkingDishwasherMaintenanceDishwasherResidue and Film on Dishesheatman101 Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
9/15/2011 2:37:41 AM • GE 24 in.... • Answered on Sep 15, 2011
GE Dishwasher PDW8280J10SS I have successfully
Hello & Welcome to FixYa
Please check this parts image for reinstallation, if this won't help then you can view this video for step by step instructions:
Please get back to me if you have any other questions.
Kevin
6/26/2011 8:54:11 PM • GE 24 in.... • Answered on Jun 26, 2011
Plastic wheels on lower tray
greetings,
plenty of places... www.sears.com is one
4/26/2011 12:48:39 PM • GE 24 in.... • Answered on Apr 26, 2011
Have a GE Profile PDW8280 dishwasher. My dishes
If you have cleaned the filter sump and you are sure the kitchen side of the drain hose is ok, then I suspect there is some problem in the separation circuit between the wash and drain pumps in the dishwasher.
See this diagram.
The turbidity sensor (item 321) could be faulty. This is supposed to check wash water quality and drain it out and bring in fresh water during wash cycle. The other possibility is the flapper valve (item 328) is not working properly. This valve is supposed to separate the drain and wash sides of the dishwasher.
First thing to do is buy a dishwasher cleaning kit (Finish brand if you can) from the supermarket and run empty dishwasher with it according to instructions on the kit. Use the hottest cycle available.
If this does not affect the quality of wash, then start checking the parts I mention above.
Hope this helps.
3/30/2011 10:09:11 AM • GE 24 in.... • Answered on Mar 30, 2011
Water will not fill in the dishwasher
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble
No Water entering Dishwasher
heatman101
2/22/2011 1:30:59 AM • GE 24 in.... • Answered on Feb 22, 2011
My dishwasher barely cleans my dishes. i
sounds like the pump or drain is stopped up. is there water in the bottom after the Cycle is done?
12/29/2010 1:22:47 PM • GE 24 in.... • Answered on Dec 29, 2010
Dishwasher does not drain completely. Then when
Sorry to read about your problem, I hope this helps you out.
you have a clogged pump or hose
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
12/24/2010 6:21:37 PM • GE 24 in.... • Answered on Dec 24, 2010
Will not pump water to dishwasher from wall
How old is it? Some times deposits get clogged in the plastic water lines after a while. See it you cann disconnect them and have a bucket to catch the water. If it flows freely then yes the water pump could be out but also could be a broken belt drive or needs adjustment. Reply back if this doesn't work and I will research it more.
12/11/2010 10:47:32 PM • GE 24 in.... • Answered on Dec 11, 2010
GE 24 in. Profile PDW8280JSS Built-in Dishwasher Logo
52 questions posted
Top GE Dishwashers Experts
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
GE Dishwashers
  • GE Dishwashers
Most Popular Question
ge dishwasher pdw8280j10ss
  • Dishwashers
