20 Most Recent
Broan-NuTone N-QT140L Combination Light Fan Exhaust Fan Questions & Answers
Fan is making ratteling noise.
pull off cover and check fan for a loose bearing. "will wobble if it has a loose bearing". if not a bad bearing then tap on moptor housing while on and be careful not to touch a fan blade. then replace cover in reverse. :)
Broan bath fan motor has bad bearings.
The motor is usually not repairable. You can sometimes purchase the motor and fan separate but that is about it. Here is a link to a blog about replacing motors.
http://nutoneproducts.blogspot.com/2009/05/broan-bath-fan-motor-replacement.html
How to change the light bulb?
Pull the cover from each side directly straight down. The cover will come down about 2 inches. Reach up on either side and squeeze together the spring to release it from the housing. The cover will swing down. Replace bulb. Squeeze the spring back together and initiate it into the housing. The last step is to push vertically the cover back up in to the housing.
