20 Most Recent
Samsung SyncMaster T260HD flat panel TFT 25.5" Monitor Questions & Answers
How to take apart
problem is in the flash light inverter logic card. the HT power choke is gone weak. replace this and also check the supply capacitors are conected to this circuit
7/4/2014 9:11:15 AM •
Samsung...
Answered
on Jul 04, 2014
Samsung t260hd firmware
Go to menu of screen look for defrag or degause press once should sort it self out, if not onboard power supply is faulty of screen take to computer repair shop.
12/31/2013 7:18:39 AM •
Samsung...
Answered
on Dec 31, 2013
All of a sudden the
You need to adjust the screen resolution.
Go to Control Panel - Display - Settings tab - change the Screen resolution.
Start at 1024 X 768 resolution and increase the resolution till you find a setting that suits you.
6/9/2011 1:23:49 AM •
Samsung...
Answered
on Jun 09, 2011
My Samsung Syncmaster T260HD displays some print
first uninstall dispaly driver from computer then instal again.
set dispaly property screen resolution to 1024*768
then check.also reset alls ettings of lcd monitor to default in menu
7/5/2009 12:11:53 AM •
Samsung...
Answered
on Jul 05, 2009
How to fix pink colur screen on sync master 794 mg samsung
The connecting cable or the video card would be the first suspects. Try a different cable to connect the monitor first, if there is no change, the video card in the computer would be second to look at. Can simply connect a different monitor to your computer to troubleshoot this. If the testing monitor works, it will be the graphics card that is the issue.
6/19/2022 1:41:48 PM •
Samsung...
Answered
on Jun 19, 2022
