20 Most Recent
GE 24 in. Profile PDW9280JSS Built-in Dishwasher Questions & Answers
Error code
you have set it to start after a one hour delay- just press the start delay button until it cycles through past 24h and you will get back to the immediate start mode...
7/8/2018 1:32:01 PM •
GE 24 in....
Answered
on Jul 08, 2018
Dishes not coming clean
Five common causes:-
1. The dishwasher hasn't got any salt in, or the salt dispenser control is set too low. Even if your tablets/powder have a salt function, it's often not enough in hard water areas and supplementary salt must be added to the salt dispenser.
2. There is no rinse aid in the machine or the dispenser control is set too low. Supplementary rinse aid may be needed even with tablets/powder which claim to include it.
3. The dishwasher is not reaching the correct operating temperature. This can be due to a faulty machine, or by using low temperature washes inappropriately. Low temperature washes are only suited to very lightly soiled loads which have not baked/dried on. There ARE special low temperature tablets/powders, but they're designed only for specialised domestic machines with low temperature overnight wash cycles or for commercial dishwashers.
4. The filters/debris traps at the bottom of the machine are not clean.
5. You're using the "wrong" brand tablets/powder. In this instance "wrong" simply means that your machine just doesn't get on with the brand you're currently using. price has little to do with it; I find with my current machine that the market leading expensive brand works poorly but the ultra-cheap supermarket basic value brand works perfectly. Also it can be down to using a genuinely wrong tablet/powder choice as per suggestion #3.
11/17/2012 4:48:20 AM •
GE 24 in....
Answered
on Nov 17, 2012
Dishwasher will not operate
How long have you had the dishwasher? Is it just dead??? Are there any lights on the keypad at all? I had the same problem with mine and the answer I got was that it was either the door latch, keypad or the control module...
8/25/2012 2:24:04 AM •
GE 24 in....
Answered
on Aug 25, 2012
GE DISHWASHER PROFILE PDW9280 WILL NOT DRAIN LAST
Hi.
Check that the drain hose is set at the correct height, as specified in the manual. Otherwise machine will not drain correctly.
Check that drain lines are clear.
Check Part # 328
VALVE FLAPPER, and Part # 505
SUMP INLET , Sump filter and parts (see diagram)
.If there is no problem with parts above, and pump is new, then the control module must be tested reading volts at pump. For safety reasons the test is better done by a technician.
4/28/2011 8:05:27 AM •
GE 24 in....
Answered
on Apr 28, 2011
My GE Profile dishwasher doesn't clean my dishes
Take off the arms and go outside with a hose and spray nozzle. If you spray it in the big inlet you can see which holes are blocked. I did the reversve and sprayed in the small holes and watched all this junk come out the big inlet. YOU WILL GET WET. it helps if you have a second person to help block other holes and do one at a time.
2/19/2011 7:31:08 PM •
GE 24 in....
Answered
on Feb 19, 2011
