20 Most Recent Compaq Presario F767NR Notebook Questions & Answers
2answers
Hi, I have a Compaq Presario F767NR. I downgrade
Contact Microsoft Windows Support Toll-free phone number +1-877-242-3672 USA and find instant help to Downgrade windows in windows XP by Microsoft experts technicians. For More Details Visit Downgrade windows website: 1 8772423672 Downgrade windows 10 How to Go Back to Windows 7 8 8 1
3/28/2018 6:47:18 AM • Compaq Presario... • Answered on Mar 28, 2018
I cant turn on my compaq presario f700
Check the fuse in the plug. If this is fine check for an output voltage from the AC adapter usually about 19.5 volts DC. If this is present it is like you have a damaged DC connector on Laptop motherboard.
1/20/2015 10:09:13 AM • Compaq Presario... • Answered on Jan 20, 2015
When I put the laptop to sleep, it won't turn on when I go to wake it up
Turn off the hibernation feature. The only way to fix this issue is to upgrade the firmware on the motherboard. Simple to do but you run the risk of ruining the motherboard is you do it wrong.
1/20/2015 9:59:12 AM • Compaq Presario... • Answered on Jan 20, 2015
Compaq Presario F767NR wifi overheating video card
When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail. A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust. Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
1/30/2013 9:05:45 AM • Compaq Presario... • Answered on Jan 30, 2013
F767nr laptop screen will not turn on
Either the LCD convertor or the screen has gone bad.
12/21/2011 4:42:13 AM • Compaq Presario... • Answered on Dec 21, 2011
Donwload and install bluetooth?
http://download.cnet.com/bluetooth-software-ver-6/3000-2108_4-162222.html
http://download.cnet.com/%7Bvalue=http://www.download.com/bluetoothview/3000-2648_4-10800572.html
Runs in the background, and monitors the activity of Bluetooth devices around you. The BluetoothView application was designed to be a small tools that runs in the background, and monitors the activity of Bluetooth devices around you.
hope this helps you
11/21/2011 4:23:08 AM • Compaq Presario... • Answered on Nov 21, 2011
2answers
Need help with compaq presario f767nr laptop, it
"start comp. In safemode". Hello???? He can't get it stay started. Remove the nickel like battery on the motherboard for ten seconds and put it back. This process will reset the motherboard to default. If u still have the same problem then you'll have to test each hardware component. If thats too timely then get another computer. Its cheap these days. Suggestion of componence to check; if memory problem ur mobo will beep. If hardisk problem ur compu will remain to stay on but blank screen. If video card problem then u get wat u got turns on then goes off
9/23/2011 2:51:35 PM • Compaq Presario... • Answered on Sep 23, 2011
My dvd drive disappeared from
Does BIOS still recognize the drive? Also, check to make sure the IDE / SATA cord is fully connected, the dirve will operate with power, but wont be recognized without the other cord. If the cords are connected and BIOS reads it then win7 should autodetect it. If its not, it may be the disc itself, try putting something you know for a fact works. If the problem persists, try adding the hardware through the device manager, or deleting all mention of it, then re-adding it through the device manager. This tricked worked for Xp machines, although Ive never had to try it on a Win7 machine, it should still work.
7/28/2011 6:26:34 AM • Compaq Presario... • Answered on Jul 28, 2011
2answers
No sound from speakers or
you must download the audio drivers on the HP website http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3682526&lc=en&cc=us&dlc=en&lang=en&cc=us&submit=Go%20%BB
select your operating system and make sure you select if you have a 32 bit or 64 bit operating system once drivers are installed you should get audio out of your headphone jack if you still do not get no audio then i would contact HP for repair
3/1/2011 3:44:15 AM • Compaq Presario... • Answered on Mar 01, 2011
I have a compaz f767NR laptop in which the DVD
I am having the same problem. I have a compaz f767NR laptop in which the DVD drive is not reconigzed by the laptop. I have already looked and tried many different solutions and all have failed. It is not visible on device manager I tried changing the registry but missing lower and upper filters. I also tried the windows fix it but still unable. I have vista home premium. Any other solutions?
1/9/2011 4:46:20 PM • Compaq Presario... • Answered on Jan 09, 2011
2answers
The laptop will not read the CD inserted in the
Hi there.
To narrow this down, try a different CD or DVD. If it's working with another disk, then your problem is likely that the disk is scratched or broken. If it doesn't, then it could be a hardware problem.
To rule out a software problem, go to Start > My Computer, then double click on your DVD Drive. Make sure the disk is in it. If it doesn't recognize it, then the problem is with the optical drive itself. The first thing I would suggest is going to Start > Control Panel > Device Manager, removing your optical disk drive then restarting the computer.
If this doesn't fix the problem then your disk drive may have overheated or the laser lens inside needs to be cleaned. However, unless you know what you're doing, this should really be done by a service technician. You can cause permanent damage to your Notebook if you don't know what you're doing inside of it.
1/6/2011 12:29:18 AM • Compaq Presario... • Answered on Jan 06, 2011
2answers
Can't find Window's 7 audio
Good luck... this is not easy even when you think that you have found the correct drivers.
with that out of the way try cnet downloads or hp website (the later being the best choice they have a pull down menu that will lead you to it).
good luck
12/14/2010 5:19:30 AM • Compaq Presario... • Answered on Dec 14, 2010
I have been having power with power lately. My
Get a can of air. Blow the intake vents out. Buy a notebook cooler. Your laptop is overheating that's all. FYI. The laptop draws air in from the bottom. Only place your laptop on hard, smooth surfaces as this will help with air flow. That means don't put it on your bed or the carpeted floor.
Example of notebook cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16834997819
11/30/2010 7:48:32 AM • Compaq Presario... • Answered on Nov 30, 2010
3answers
Laptop won't come on
Unplug the AC Adapter and battery from the laptop and hold down the power button for about 10-20 seconds and put it back again. Also you may need to reseat the RAM before turning on the system.
Best of Luck
7/16/2010 1:39:28 AM • Compaq Presario... • Answered on Jul 16, 2010
Not sure how, but our Compaq Presario F767NR
it's a simple problem of smps just change your power supplier
5/4/2010 1:35:41 PM • Compaq Presario... • Answered on May 04, 2010
Dvd/cd drive does not power up at all. data/power
it myt be secure but the stepper motor myt be in failure .. please chec it even.
7/8/2009 12:48:01 PM • Compaq Presario... • Answered on Jul 08, 2009
2answers
CDDVDW stop responding
Try reseating the driver or delete registry: Follow the steps but you do that, please back up registry files by clicking on File and import:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
7/5/2009 2:05:34 AM • Compaq Presario... • Answered on Jul 05, 2009
Cq61 will not power up light flashes 3 times
In case somebody has the same problem. Result of my investigation: * If everything is ok then the Presario CQ61 boots without battery. * HP support recommends to do a hard reset i.e. remove power supply, remove battery, press power button to discharge everything internally, connect power, press power button In my case the problem was solved by changing the AC Adapter (Power supply). Note: The led besides the power connector is not reliable. It is on with the working and faulty adapter. Note: The voltage level at the battery pins is not reliable. I had same values.
9/22/2021 1:41:52 PM • Compaq Presario... • Answered on Sep 22, 2021
Compaq Presario CQ62 - Windows 8 Pro and Acrobat Reader X1.
old PC,, Cq series. cq62-nnnnn you left off the nnnnnn cq62-100, 200 ,300 what? running mS windows 8 HP does not support W8 on this PC so that means you are on your own steam... (you , it and microsoft 100%) forget ACER this is not and ACER PC< at all, (totally different) you could reload w8 , like you did before, now all that works its login password issue, can i presume the screens look ok W8login screens? local login fails, not bios, and not windows live logins fails that is right there are 3 tiers of logins. admin , create a new account and use that or do that and ask at MS how to copy date from dead account to new account, you never said once you had data. if no data on pc, then reload 8, easy no? the newer the OS the more hard it is to get data from that dead account( new permission rules, and hard to do) ask best i can tell, lacking your full model number teh CQ62-400 (newest) had only Windows 7 so how did w8 get there, from whome, and what media. and what install methods. from MS CD? or MS ISO, or from ebay hackers disks/ what? here are the ways, (not data recovery) http://www.pcdied.com/passwords.html
9/10/2017 1:44:07 PM • Compaq Presario... • Answered on Sep 10, 2017
My Compaq Presario CQ60 won't connect to wireless internet.
how'd you do 2012 post then 2017, shocking. some one needs new clock battery , LOL
8/30/2017 11:43:01 PM • Compaq Presario... • Answered on Aug 30, 2017
Compaq Presario F767NR Notebook Logo
22 questions posted
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Presario Compaq
  • Presario Compaq
Most Popular Question
need help compaq presario f767nr laptop
  • Computers & Internet
