20 Most Recent HP Pavilion dv7-1245dx Notebook Questions & Answers
does the PC run good , battery out, and only on AC, it must.
does it?
  1. bad battery
  2. bad power pack 19vdc 65w
  3. or bad charger chip in the PC.
did you give it 24 hours to charge.
HP Pavilion... | Answered on Feb 16, 2018
randomly run your fingers on your keyboard to loosen any stuck keys than restart again.
HP Pavilion... | Answered on Feb 06, 2018
go to setup and change priority to HDD.
Try removing the battery and switching on the laptop with charger only.
There is a reset option that is supposed to help if the KB doesn't work.. yours is random or sporadic but this might help:
http://hp.dezide.com/ts/start.jsp?guide=NotebookKeyboardandTouchPadorClickPad.net&as=true&SFS=sdoc§ion=ccweb&language=english&lc=en&cc=us&action=step&response=0&step=C39975.C39953&session=89f43caa-ba00-4809-80e8-eed31a
no photo posted, of bad screen, why? why make help blind?
the display LCD is bad.
or is the 2008 , solderballs Nvidia chip failure.
if the screen fails in BIOS (press f10 or ESC to enter setup
an fails under boot CD linux or any kind the screen is bad
test with big battery out, always. run on AC power only to test.
do the funny LINES change if you gently twist screen case?
i see reviews on this LT back to 2009
the vista review page on its support pages is stamped 2008
oops !
the BIOS screens are here. hit ESC then F10
dv7-1245dx
this is called hp setup, its BIOS.
if these screens look bad, bingo for bad screen LCD or the GPU.
http://h10032.www1.hp.com/ctg/Manual/c01662442
HP Pavilion... | Answered on Jan 01, 2018
go to control panel -> system and security -> system -> device manager. that has a list of all the hardware on the computer, look for any items that have X ! or ? next to them. Could be that you don't have a driver loaded for that device.
HP Pavilion... | Answered on Dec 23, 2017
Are you Install voice control any software on your computer. cheek your control plan apps list.Are its automatically install uninstall them.
HP Pavilion... | Answered on Nov 25, 2017
You need to get into the BIOS screen and set the boot order so that the CD drive boots first. Then it will boot to the cd and tell you the same thing. That the hard disk has failed and cannot be found.
HP Pavilion... | Answered on Nov 22, 2017
From the description of the problem, this seems to be a driver issue. What Operating system are you using?
HP Pavilion... | Answered on Apr 13, 2017
Most likely it is a fan problem. The fan could either be failing or caked up with dust. Most likely the laptop would have to be disassembled to get to the fan and repair/replace the fan.
thank you,
Lee
HP Pavilion... | Answered on Jan 05, 2015
Hi there! asking for keyboard lights! some of the solutions for ur problem are:
1. use external laptop keyboard with lights that are available in nearby PC store or electronics store else u may try it on online stores that may even offer deals.
2.Use USB light that illuminates light on keyboards that are more cheaper than keyboard replacement
3.If you are a DIY enthusiast and have hobby, and known knowledge of electronics try making LED illuminare from Ur laptop usb dongle out it may hav 4 pins say positive, negative, data positive and data negative and it supply around 5V supply with 1 amp current. try it may cost more cheaper than two solutions as i said above.
4. use low power bed lamp that focus on ur laptop keys.
thats all bro! Have a nice day! bye! any question : rameshprabu@in.com
HP Pavilion... | Answered on Nov 27, 2014
another method I have used that works is to remove CMOS batt as you have done before - do not replace it yet though.Power on the dv7 without the battery in then off by holding down the button until it switches off.Remove AC power hold down power button 5 secs to dissipate power and replace CMOS batt,plug in AC and test.Hopefully it clears the bios settings for you
HP Pavilion... | Answered on Sep 02, 2014
Check power settings,display will dim on battery power by default.Settings for display brightness are adjustable for AC and battery power.
Dv7-1245 todav?a es un port?til muy agradable.
El procesador se encuentra en su dv7-1245 es el
AMD Turion X2 con tecnolog?a m?vil RM-72 / 2.1 GHz
un reemplazo para ese procesador corre alrededor de $ 190 aqu?
http://www.pcrush.com/product/AMD-Processors/236482/AMD-Turion-X2-RM-72-Dual-core-2.1GHz-Mobile-Processor#product-reviews
o se puede disparar para una actualizaci?n de un 2.4ghz 250 aqu?
http://www.google.com/products/catalog?q=socket+s1+processor&um=1&ie=UTF-8&cid=14671136682080307777&sa=X&ei=vTNvTdOYHoHAtgfl7Jz2Dg&ved=0CCEQ8wIwAg#
Cualquier procesador Socket S1 trabajo en el dv7
Si esto le ayuda a asegurarse de que lo diga:)
HP Pavilion... | Answered on Apr 28, 2014
Dear Sir/Madam...
You just follow these steps:
1.Remove the battery and Adaptor
2.Press and Hold the On buttun for 30 seconds (without battery/adaptor,this is for reset the BIOS in your Laptop)
3.Now you just connect the adaptor with your laptop
4.On the adaptor socket main switch in main board
5.Watch the Laptop charging Light is ok or not.Also watch the Light in Adaptor is lighting normally or not.if all are normal then try 6th step otherwise problem in your Laptop.Just go for an authorised service center.
6.Try to ON the Laptop
All the Best....
thank you very much By Ganesh(INDIA)
6.
HP Pavilion... | Answered on Mar 28, 2014
Try to connect to an external monitor and see if this give an image. If it does, then the Inverter / backlight or possibly the VDU cable on your laptop is damaged.
If it does not, the issue is most likely a failed graphics chip (common on these models). You CAN get the chip "reballed" but this will cost about £70.00, and not guaranteed to last
HP Pavilion... | Answered on Jan 22, 2014
It can probably be a missing driver issue however you can fix this issue by downloading appropriate driver from your machine`s manufacturer website and then re install it.
HP Pavilion... | Answered on Oct 31, 2013
look it up on youtube
HP Pavilion... | Answered on Oct 30, 2013
HP Pavilion dv7-1245dx Notebook Logo
189 questions posted
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Pavilion HP
  • Pavilion HP
Most Popular Question
mic will not work just signed up skype
  • Computers & Internet
