20 Most Recent
Dell Vostro 1710 Notebook Questions & Answers
Having problems with my Dell laptops' hard drive
Hi Lofimodernis
Regarding your inquiry unsing a USB 2.0 external or HDD enclosure is basically used to connect a laptop HDD to another computer to be used to extract or back up files on to new HDD or another device. regarding with the error 2000 0146 as far as i can remember as a technician when it comes to dell laptops it would really be a HDD replacement
Hope I have answer your inquiry about the USB 2.0 external enclosure
Thank you for choosing fixya support
I accidentally pressed a combination
If something went wrong on your computer and you wanted to revert to an
earlier restore point that was taken either automatically or manually , you can do so by using the System Restore application.
Click on the Start button All Programs > Accessories > System
Tools, or by typing
rstrui.exe from the Run option:
Note that running System Restore requires administrative permissions.
System Restore can be run and allowed to select the "best" restore
point to which to restore your computer to, or it can be used to
manually restore your computer's system files to an earlier point in
time of your choice.Just select "Choose a different restore point" and
press Next.
The volume wont work
Hello Friend, There is a sound driver problem in your laptop. Install a sound driver from a driver CD given by manufacturer if it is not provided then go to the manufacturers web site n download drivers then install it. After install restart your PC n check for sound.
Hope this may solve your problem reply n vote as early as possible...
I can not find my D-drive
Right click on My computer or (Computer) click manage ,pass security control (up from vista) ,select disk managment and enable your disk.
Bluetooth & sound
Generally, connecting phones via bluetooth to a laptop just allows for file transfer between the two devices. It is not to input sound from the phone through the speakers of the laptop. You would need a bluetooth audio device for that such as bluetooth speakers or headphones
Code 10 is not starting
This error is basically saying that Windows, for one reason or another, cannot communicate properly with one of your programs. This communication problem is usually caused by out-of-date, missing or corrupt device drivers. ... Select Start > All Programs > Windows Update.
This copy of windows is not genuine
i used to get that also, I wrote down windows numbers from windows sticker on the side of machine, (needed magnifying glass) and went online to windows verify, after they scan it, it came out good
HOWCAN FIND MACADRESS WIFI LAPTOP VOSTRO1500?
Open a command prompt ( Windows key + R to open Run box, then cmd), and type
ipconfig /all
and look for the wifi adapter. The entry labelled "Physical Address" is the MAC address. It will look something like 84-3A-4B-C8-E9-B7
(Your router might want it entered in the format 84:3A:4B:C8:E9:B7)
Cpu overheating
The cooling fins on the processor chip are plugged with dust. The fan may not be turning fast enough. If that's the case you'll need to replace the cooling fan
Wifi hotspot
WiFi will in the laptop will connect to a wireless router or a hot spot. The laptop itself has no hot spot built in.
