20 Most Recent
Apevia Aspire One A150-1777 Netbook Questions & Answers
How do I reset my acer aspire one A150 to factory
InstructionsClick "Start" and select "All Programs."Click "Acer Empowering Technology," then "AcereRecovery Management."Click "Acer eRecovery Management" in the Acer barthat appears on your desktop. The "Acer eRecovery Management" window will open.Click the "Restore" button.Click "Restore System to Factory Default." Click"Yes" to confirm. The system will restart and reset itself to factory settings.
How do you use a webcam on your computer
1. install the driver first.
2. connect it to your computer ( to usb if wired)
3. go to control pannel and click on webcam option.
you will find the camera showing your background.
thanks.
How can I use my webcam?
In windows explorer, there is a listing (like a drive) for the web cam. Click on the Web Cam in the left pane and the right pane shows the display.
Aspire 4736z422g25mn
unplugged the cable, and pull out the battery for a few minutes, like a 15 min and conect all and try, its the problem persist change the internal watch battery
Aspire one d2500dr
I assume you're running Windows 7 or 8. In general, you can't uninstall wifi--but you can certainly turn off your antenna (usually a switch on the side or front of the laptop) or you can tell windows to forget about a particular network.From the sounds of it, you probably did one of the two and now you cannot connect to the Internet. If you want explicit instructions, I need to know which version of Windows you're running (XP, Vista, Windows 7, or Windows 8).
