20 Most Recent
Dell Precision M4400 Notebook Questions & Answers
Dell keyboard not working?
If you have access to an external keyboard, plug this into your laptop USB (or PS/2) port. If this works you may have a faulty keyboard on your laptop.
Sleep function
Usually pressing the power button once will wake a computer from sleep. Often all that is needed is a mouse movement or hitting the enter key. If your are in Hibernation mode as opposed to sleep mode
The key stroke(s) needed will be in the Power Settings section of control panel.
Base system device
Just what do you mean by base system device? Are you relating to the Windows Operting system or what?
I forgot my pass word
start computer computer ask password enter wrong password. and now click on reset password option. you can reset password now
Space bar not working
Does it click in a normal way? does it feel ok when you push it, or does it feel stuck? Tried blowing it with compressed air?
How to enable internet on Dell Precision M4400
fistly confir that which antivirus u use.
if it norten, thn follow these step.
Scan for Internet-Enabled Programs and Apply Firewall Rules Using the Interface
Double-click the icon in the system tray to display the Norton Internet Security window.
Click to select Status & Settings and double-click Personal Firewall to display the Program Control screen.
Click the Program Control tab:
If the Manual Program Control list is empty, click Program Scan to look for programs that use the Internet.
If the Manual Program Control list is not empty, click all the check boxes and press Delete and then OK.
Click the Program Scan tab to display the Program Scan window.
Click to check the scan boxes under choose the drivers you want to scan.
Click Next to allow the Program Scan to list all the Internet-enabled programs found on your computer.
Click All to select all or check the box next to each program name to select the programs that you want to create firewall rules for and click Finish.
Note:
All the programs that you select appear in the
Program Control dialog box. In almost all cases, you do not need to modify the
Internet Access or
Category options. If you do need to modify these options, click the triangle to the left of the option in the
Internet Access column and select the change.
Click OK to return to the Norton Internet Security main window.
Re-enable Norton Internet Security and launch the program that is having difficulties accessing the Internet.
If the application now works with your Internet connection, you have successfully created firewall rules for the programs you selected.
If the application is still not working with your Internet connection, proceed to Check if a rule in Norton Internet Security or Norton Personal Firewall is Blocking Internet Access
