20 Most Recent
GE Profile Spectra JGBP79 Gas Kitchen Range Questions & Answers
GE profile gas stove igniter don't stop igniting
take a look at the igniter located in the center of two burners. clean the gap with a stiff brush between the eletrode and the upper plate. the distance is preset at the factory. you may have enough buildup to close the gap enough to trigger the igniter.
GE WB2X9154 Igniter Wires
its making a circuit, just see which way the spark is jumping then you will know if it is going the right way, like a light bulb it will work either way
My error message says FC the oven door is locked I
The self clean option usually can't be stopped once its started. you may have to let it finish its cycle (a few hours) and see what happens from there. It also sounds like you could have a bad door sensor switch.
F1 and beep on my
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced
GENE
Installing WB2x9154
For women from a woman's point of view: Most if not all the screws were hex head 1/4. Have appropriate tools. A socket set will work. I like my little cordless screw driver. You will also need wire strippers and two wire nuts, they say ceramic wire nuts and electrical tape. It is also a good idea to have a someone else there for safety sake. I tipped the stove back.
Take everything our of the oven. Take big screws out at the back bottom of oven. Lift bottom of oven and push toward the back of oven. (There is a lip at the front that oven floor slides unde). Be careful as there are sharp edges all over the place once this oven bottom is off. Next unscrew the screw at the front middle of oven that holds the long burner in place. Next pull the stove drawer out and set aside. Pull stove out just enought to put large juice cans under the front legs. Way at the back you will see where the burner comes down to the gas line. There are two screws holding it to the back of the stove, remove them. Next find the two wires that come from the igniter. Unplug them. Lift out the burner. Unscrew the two screws that hold the igniter on to the burner. Carefully put the new ignitor on the burner. If the new ends do not match the old ones or if they are shorter, cut the old ones off near the old ignitor. Cut the ends off the new ignitor as far from the ignitor as you can. Clean the ends off so that about a half inch of wire is bare. Put the old ends on the new wire so that you can plug them in. Hold the two like wires so that both bare wires are parallel and screw on the wire nut. Lay it parallel to one wire and wrap electrical tape around it so that it will not pull loose. Plug in the way it was originally. Put everything back together opposite of the way you took it apart.
