20 Most Recent
Nextar X3-08 Car GPS Receiver Questions & Answers
How do I update my Nextar x3-08 gps so the new roads will show up ?
visit Nextar.com to order your desired maps update and Check the overview description to see which SD card lists your GPS model number and serial number. Order the matching card.
Remove the existing SD card. This is usually found in a thin, rectangular slot on the side of the Nextar GPS.
Insert the SD card with the maps update into the empty SD card slot. Press until it clicks into place.
Reset the unit by pressing the "Reset" or pushing a pin into the "Reset" hole.
Click the "Navigation" button to have the maps automatically update on the GPS.
I Have A Nextar gps it is a x3-08 is there some way I can get up dates for it ?
Your device runs Windows ce. So the only way to continue using your device is to switch software. There is a software that is compatible with almost every GPS in the world today. It is called IGO. Maps are available every 4 months for free. Search google for IGO and there are plenty of GPS sites that offer it for download. All you have to do is rename the IGO.exe file you your devices navigation.exe name. If you need further assistance I'll be glad to help.
Battery replace
Unscrew the 4 screws on the back and gently pry open the casing with a guitar pick or an old giftcard. You will have access to the battery. Good luck...
I have a Nextar x3-08 gps. It will not go beyond
Once again, it's a software issue or a corrupted SD card. You can purchase a new card but the same old mapping on Nextar.com or Navteq.com. To ensure that your software stays working properly, backup the SD card onto your computer so if the SD card gets corrupted you can restore the software and files back onto your card or a new SD card that can be purchased for around 20 bucks.
Unit will not power up
There could be few reasons for this problem.
1. The
built-in rechargeable battery is almost dead. Please recharge the battery. If the battery is almost dead then it will not turn on even in in the initial hours of charging. Charge it longer than useal.
2. The battery has reached end of life. Replace the battery.
2. The
unit may be obstructed by a material such as heat insulation, please remove the
obstruction.
3. The
unit may be titled too far; please hold the unit upright.
4. If
the system software fails to function by chance, please restart the unit again.
My strong believe is that the problem is in the battery. Please make sure your AC adaptor or car adaptor is properly
connected to the main unit and that the adaptor is receiving AC power. If
problem persists, there may be a hardware problem with charging circuit.
