20 Most Recent Dynex DX-LCD32-09 LCD TV Questions & Answers
2answers
Tv turns on, says please wait, then goes black and nothing happens
The firmware to your TV might have corrupted. It should be upgraded.
11/13/2021 1:32:00 AM • Dynex... • Answered on Nov 13, 2021
2answers
Antenna not finding channels
I had the same problem, Took it back to Wallmart.
2/24/2020 3:38:12 PM • Dynex... • Answered on Feb 24, 2020
I have a dynex 55 inch tv it turns and runs for a
I would recommend doing power cycling your TV. Turn it off, unplug it and leave unplugged for a few minutes, then plug it in and power it on. If this doesn't fix the issue, then I would also ensure settings are back to factory defaults. Press MenuPress Left or Right to select Setup, then press Down to open the Setup menu.Press Up or Down to select Restore Defaults, then press Right or Enter. When a message asks if you want to restore factory settings, select Yes to restore the settings, or select No, to exit without restoring settings.
1/19/2018 10:01:34 PM • Dynex... • Answered on Jan 19, 2018
I HAVE A 32 INCHES
do you have ebay you can use theres alot to pick from
10/23/2017 10:36:37 AM • Dynex... • Answered on Oct 23, 2017
Can't get rid of "Please Run Channel Auto Scan" stays on tv screen
for some reason it is not seeing you cable signal. you will need to make sure you have it set up for cable and not air. check your input options, like tv/av/hdmi/ ect hope this helps
5/17/2017 2:50:26 AM • Dynex... • Answered on May 17, 2017
Have DX-LCD32-09. When I plug in headphones the built-in speakers don't cut out which defeats the entire purpose of headphones. No menu options help, headphones work fine elsewhere.
Headphone socket [inside the TV] is faulty. Replace it. 26322365-ifg43imtoe0ib4k3zeijlduf-1-0.jpg 26322365-ifg43imtoe0ib4k3zeijlduf-1-2.jpg 26322365-ifg43imtoe0ib4k3zeijlduf-1-5.jpg Will look one among like this, directly soldered to the printed circuit board [Main board]. http://electronicshelponline.blogspot.com/
10/22/2016 8:24:02 AM • Dynex... • Answered on Oct 22, 2016
Tv powers up to green,but just lights up dark blue screen,nopicture,sound,etc.
I just answered that a while ago, why do you people ask the same thing several times?
4/17/2016 5:30:19 AM • Dynex... • Answered on Apr 17, 2016
How to get the writing off the screen when watching television. tried setting, closed caption off. nothing works.
If you have changed the settings with the "television remote" then you need to do it with your cable remote or vice versa.
4/8/2016 12:24:53 AM • Dynex... • Answered on Apr 08, 2016
0answers
0answers
Edge to edge picture
Be the first to answer 2/28/2016 6:44:36 PM • Dynex... • Posted on Feb 28, 2016Be the first to answer
2answers
Dynex 32" LCD - bottom 2/3 of screen is black w/ colored lines
My screen looks EXACTLY like that! I called Dynex and they told me my warranty is out and they cant fix it. I have only had this TV a bit over a year. Did you get a resolution??
2/18/2015 1:57:40 PM • Dynex... • Answered on Feb 18, 2015
Where can we get replacement cord for Dynex TV?
I would suggest Googleing your Dynex Model # and see if you can find accessories for it. These cords should be all over the internet.
12/8/2014 12:54:46 AM • Dynex... • Answered on Dec 08, 2014
2answers
I have a Dynex 32 LCD that I can only see the top half of the picture, the bottom half/40% looks like rainbow lines. What are the possible problems and how do I fix it.
Unfortunately what you have is a fried screen. Toss it at the city dump and get a new TV. Wallmart has 36 and 45 inch TV's for under 300 dollars Good luck
11/30/2014 11:19:05 PM • Dynex... • Answered on Nov 30, 2014
Dynex PO2-w30-003s no picture sound ok
put a flashlight behind the TV screen or front screen close, just try as close as possible, if you see image that means that the Back-Light inverte is defective or the screen lamps are not working, if deres no imagen the video card is not working (main board)
8/6/2014 3:27:28 AM • Dynex... • Answered on Aug 06, 2014
Why my screen says please wait then goes black
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors - Flickering screen - Screen image disappears after several seconds - Dim screen - Slow start - Power LED on, but no picture - Unusual colors and/or lines The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad. If they appear bulged on top, then they need to be replaced. New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years. Check the cables, connectors and connections. Take it to a repair shop.
5/5/2014 7:46:47 PM • Dynex... • Answered on May 05, 2014
My LCD dynex tv will turn on but keeps flashing on and off saying please wait
The fact that Please Wait appears on the screen that the power board is fine. I would unplug the tv for 4 hours and plug it back in to see if the same thing happens. It does appear that you need to replace the main board,
4/17/2014 4:08:08 PM • Dynex... • Answered on Apr 17, 2014
162 questions posted
Top Dynex Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Jesse Walters
Jesse Walters
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Dynex Televison & Video
Most Popular Question
dynex tv green black in picture
  • Televison & Video
