20 Most Recent
Sabre LCT371BKA LCD TV Questions & Answers
Sabre 37in multisystem TV has
TV's operate on 110 volts, not 220 volts. You need more than just an adaptor to plug in your TV. You need to use a voltage converter to bring the voltage down to 110 volts. But since you already connected your TV up to 220 volts, damage has already occurred to the sensitive electronic components and you need to get it repaired.
Red light blinking. How to stop it.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
My Sabre LCD TV
My TV just did this 2 days before Thanksgiving. I just messed with it and fixed it today. Unplug it from the power source for atleast one hour. Plug it back it. Hold the power button til constantly flashes red and green. Wait at least one minute while it continues to flash. Turn it off. Flip the big power source button on the back to off && then on. Then hit the power button on the side, and it should turn on. Worked for mine. Hope it helps.
37 remote code
0093,0048,0027. Try these codes. If
you wish to get some details, check the sites linked here. Set-up code list, and Set-up procedure to
many popular brand remote controls are given.
http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to
Mosaic
/ Timeslide, can be selected by the
drop-down list, at the top left
of the display window, will make surf easy. You can also do a
search, by type in the
brand name of your TV / Device, in the search box
at the top right of the display window.
The picture is shifted to one side. I have tried
It sounds that the software loaded has been corrupted by anyway. If so, a software update might be necessary. If you wish to get more details, check this link. It has details about software upgrade. Go through it, and if you're confident, do a software update. If not, contact any service technician.
Pull up previous posts by its left sidebar, or
type in the
brand name and model number to of your set, to its
search box, and press '
Enter' or view it in
Mosaic /
Timeslide option.
