20 Most Recent
Panasonic Viera TC-L37X1 37 in. LCD HDTV Questions & Answers
What is wrong with my tv
if there was a storm ,there is every possibility that there was a power surge that has fired parts of the circuit board
I suggest that you have it check at an electronic shop and get quotes for repairs.
Screen dont display
Check and replace the power supply board. It might be faulty. Normally, there is no service to these boards. Only card base replacement can be done, and it is good too.
If you wish to get more details, check the site linked
below. Pull up older posts there. Check
the site with patience, as it has over 2400 posts now. All are related to electronic equipment
repair help. If you search the site in
Timeslide option, which can be selected from the drop down list at the top left
of the display window, it will be easy to locate the related post. You can also do a search by type in the
brand name to your device into its search box at the top right of display
window.http://electronicshelponline.blogspot.com/
After the recent heat wave
I would suggest that you may have a contaminated mini switch on your customer on set keypad. If one or more of these switches show a high resistance reading when not pushing on a key, it's contaminated. I usually replace all the switches to correct the issue. Encompassparts.com list this number as the control panel assembly. K0RB00700013, $16.98 for part.
This would be the first thing I would try.
How can I have a full view of a hd station?..
If you have to use the "ASPECT" button on the remote, set the screen to "JUST" it gives you full screen without "morphing" the picture. If you are using HD cable, SAT, Or FIOS, check the main settings menu in the cable/sat/fios box. make sure its 16 x 9 or "Full" If you still have an issue, post a comment with the details of products connected to your TV. Makes and models and I will help you further. Hope this helps.
Panasonic Viera HD LCD
Turn it on, have power and
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there are some troubleshoot you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Hi i have a TC-L37X1
This happens because either the HDMI cables are defective or the signal path goes thru a device that isn't fully HDCP compatible - the system thinks you are trying to copy the movie or whatever without authorisation+ you're a pirate.
Panasonic hd tv suddenly power
Unplug,replug about an hour.Have the same problems.The power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
