20 Most Recent
Nokia 6710 Navigator Cell Phone Questions & Answers
Hi. I forgot my enter passcode of nokia 6710
iF you forgot your password to unlock your phone you can do a hard reset or if you dont want to loose your personal information you can try doing soft reset:
To hard reset your Nokia 6710 Navigator you just have to press *#7370# and press Dial. The phone will request the security code that is by default 12345. Please be aware that you will loose all the data in your phone, so you should backup all relevant information.
If you want to soft reset your Nokia 6710 Navigator you need to press *#7780# and then Dial. The security code is 12345. Once you complete this, your phone will come back to factory settings, but you will not loose personal data. Anyway it is recommended to make a backup before performing any of the mentioned procedures.
GOOD LUCK
Forgot lock code
If you have forgotten the code then all you can do is re-install the firmware. Yes, you will lose all data.
Keypad not working
you need to open the cell, and clean the keypad, from dirty, corrosion, bad contacts, oxide, with contacts cleaner. do it and fix itGod bless you
Unlock code for noia 7610
To get the unlock code for Nokia 7610 mobile, you need to provide the details like country and network it is currently locked in the site
Theunlockarena.com . They will send you the code through mail with instructions to unlock it easily.
Powers off by itself
Sir/MamTry to Switch on and see it happen again (white screen) or not?If it happen again try be replacing a new battery and see. And if you have the same problem again then it must be your OS (Operating System) corrupt...So, please refer to the nearest mobile service for FLASHING and see..Thanks!
O signal
Hello My Dear::":":defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
