20 Most Recent Nokia N86 Smartphone Questions & Answers
2answers
Volume button is not working
n86 tkey buttom not warking
1/16/2017 10:05:41 PM • Nokia N86... • Answered on Jan 16, 2017
2answers
How can I unlock the countrycode for Nokia N86 8MP
Please reinstall its softwere problem will be solved. Thanks
3/8/2014 3:04:12 PM • Nokia N86... • Answered on Mar 08, 2014
How can i change IMEI number for n86
try it *#06#
10/27/2013 12:34:50 PM • Nokia N86... • Answered on Oct 27, 2013
I want to up grade My phone it is a Nokia N86
You can up grad it if you want up grad version .you just to download Nokia pc suite and then you install it on computer next you connect your usb to computer next you phone choose pc suite it will be connect and you fined up date phone on pc suite programe third you click up date untill finish you don't unplug your usb second don't take out of your battery from phone when you saw your screen phone blank wait until it install finish .remember that when you up date it your computer must be connect internet .
10/25/2013 5:55:56 PM • Nokia N86... • Answered on Oct 25, 2013
Can i use n85 lcd in my nokia n86
Yes. They are compatible. Same resolution which is 240 x 320 pixels and pixel density 154 ppi.Hope this helps :)
10/21/2013 4:26:43 AM • Nokia N86... • Answered on Oct 21, 2013
I want to know whats the number of du balance
check du balence
5/12/2013 12:32:14 PM • Nokia N86... • Answered on May 12, 2013
Nokia n86 8mp back button not working
Nokia n86 back batton not working when i go back from part to another.
3/26/2013 3:54:28 AM • Nokia N86... • Answered on Mar 26, 2013
My nokia n 86 is not getting switched on after charging it overnight. What can be done to it to switch it on?
First Option:1.Check the device's battery level for at least two bars of strength. 2.If the battery level is low, charge the battery. 3.If the issue is not resolved, remove the back cover. 4.Remove the battery. 5.Wait 10 seconds. 6.Press and hold the W key. 7.While pressing down the W key, re-insert the battery. •The device restarts and after approximately 15 seconds, the 'Recovery' screen appears•Release the power button but *continue holding the home button*, for another 30 seconds.StepThanksSecond option:First Option:mostly nokia chargers doesn't make problems...just try the following..connect ur mobile with a system (usb cable)...found out whether it is charging or not...if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...if it charged with usb cable buy a new chargerPlease change Phone Bettery and check the charging
12/7/2012 9:00:22 AM • Nokia N86... • Answered on Dec 07, 2012
After taking a pic fom the camera I can't find it in the photos gallery
Generally this problem cause due to the malfunction of your memory card (mass memory).When files/data are fully loaded or sometimes when the files or data were infected by virus this problem occur.So, to get rid from this issue move all the data which is stored in your phone memory,For better result remove the mass memory from the phone,move/copy all the data/files from mass memory to your pc,format the memory card,reload all the data/files to your mass memory from your pc which you have copied/moved from mass memory.Now insert the mass memory to your phone.There will be no interruption. thanks for visiting fixya
10/30/2012 4:27:01 PM • Nokia N86... • Answered on Oct 30, 2012
Auto restart
As far as I know I think that some of the themes of your phone is corrupted/infected by virus.To get rid of this problem you need to flash the phone.If you wish to do it by yourself follow this Click here1.And here to get your flash file All nokia bb5 flash file....But it you flash with the lower version of the flash file your phone might die.So, if you do not believe just step in nearest mobile repairing shop.Good luck.Thanks for visiting fixya
10/11/2012 6:27:31 AM • Nokia N86... • Answered on Oct 11, 2012
2answers
I have n86 nokia and
10/4/2012 2:14:03 AM • Nokia N86... • Answered on Oct 04, 2012
My n86 won't charge or turn on! there is a white
i have the same problem! can someone help ?
9/15/2012 1:18:52 PM • Nokia N86... • Answered on Sep 15, 2012
Deactivate powersaving mode
n86 deactivate power saving mode
8/29/2012 7:25:19 AM • Nokia N86... • Answered on Aug 29, 2012
My radio transmitter doesn't work... my mobile is nokia n86 8mp
firstly configure it to the nearest radio centres by downloading the radio stations and then play the radio according to your preference.if the radio signal is enough good then you can play it or else not.
4/7/2012 7:24:09 AM • Nokia N86... • Answered on Apr 07, 2012
4answers
Can you unlock nokia n86 on orange for free
HI,
one time you have helped me to unlock my phone. Now I want to ask, if it is possible to unlock a Nokia N86, 8mp from uk orange???
My IMEI:354203039197613
Thanks and Regards
3/30/2012 8:27:25 PM • Nokia N86... • Answered on Mar 30, 2012
Nokia N86 Smartphone Logo
87 questions posted
Popular Products
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
View Most Popular
N Nokia
  • N Nokia
Most Popular Question
nokia n86 8mp back button not working
  • Cell Phones
