20 Most Recent
Motorola Mobility MOTOROKR Z6 Cell Phone Questions & Answers
Want new battery
visit the below link for your battery replacement;
http://shop.inspecturgadget.com/ROKR-Z6-Battery-Replacement-p/mot-rokrz6-6.htm
Good luck.
1/12/2011 3:26:47 PM •
Motorola...
Answered
on Jan 12, 2011
I want to charge my
Hi all you need to do is use google as a search or what ever search engine you use and type in the following
motorola pc suite
then hit search now when i do this the top one in the list is the downloads page for motorola in the UK so depending on where you are it should list it for your country.
the top one in the list will be motorola's own site so that would be the best and safest one to use.
if you have any problems getting the software then give me a shout back and tell me what country your in then ill send you the link for your country's motorola site.
let me know how you get on or if you need further assistance ok
please rate this solution and leave testimonial as i have a whole page of unrated posts, thanks
12/11/2010 9:40:12 PM •
Motorola...
Answered
on Dec 11, 2010
I forgot my unlock code for my motorola z6. now
Well if you are tied to a particular network all you have to do is to unlock your phone to use it any other GSM network. You can get the unlock code through online. I will suggest the website
Unlock-Zone.com which is doing good service .....you can approach this website.
12/8/2010 12:56:17 AM •
Motorola...
Answered
on Dec 08, 2010
How do i shut off my speakerphone
if you select speaker on during the call, your display
shows the speakerphone indicator until you
turn it off (press Options > Speaker Off) or end
the call.
hope this help
9/9/2010 1:26:57 AM •
Motorola...
Answered
on Sep 09, 2010
I am having problem with battery. After 2-3 calls,
hi, well it could be that the battery does not charge properly whenever you charge it...so, it could be that the charger is not charging the battery properly....if you can get another charger and see if that will charge it well, but if it does not work....you will then have to change the battery.
7/26/2010 8:27:53 PM •
Motorola...
Answered
on Jul 26, 2010
Como puedo cambiarle la carcaza ami motorokr z6 yo
loba , tenes que conseguirte un destornillador especial, lo desatornillas de atras de la pantalla( la q sube). UNa vez que sacaste los tornillos, levantas la carcaza y la deslizas un poquito hacia abajo PERO NO LA RETIRES DEL TODO!!! porque la botonera esta unida al telefono. Con un destornillador plano desenchufa la botonera del telefono ( con cuidado) una vez que esta desenchufada ahi la podes retirar. Yo estoy haciendo lo mismo pero tuve q comprar la carcaza, los botones y el lente todo por separado , si la tenes completa solo tenes que enchufar la botonera al telefono , si no asegurate de tener todas las partes (el lente si lo sacas no se puede volver a poner) Espero que te sea de ayuda, a mi me resulto facil pero el problema es que ahora se me rompio la pantalla=( pero ya me fije como cambarla. Saludos.
6/16/2010 2:46:24 AM •
Motorola...
Answered
on Jun 16, 2010
I have a motorokr Z6m and i forgot my security
the truth is that you can unlock the phone for free,but you can unlock all phone for free. The payment sites are very very cheap you could try it out and see.
There is a free site you can try out first but it is for soft
unlock not hard unlock.You can use this link for the soft unlock,
then trying out that with this site (www.unlocktotalk.com/UnlockCodeInstructions.htm),
you will now try out the hard unlock with the site below
Note:hard unlock is not free,You will be charged to get your unlock code.
The only way by which you can get the unlock code for free is by calling your service provider
and requesting for your unlock code.
If you service provider refuses to give it to you, then there is no other place where you can
get a free unlock code.
Visit the link below if you are interested in buying the unlock code:
(mobileunlocked.com/mobile_unlocking.php)
Good luck.
6/10/2010 2:01:16 PM •
Motorola...
Answered
on Jun 10, 2010
I have a Motorola Rokr
hello,
there are two two way which you can bring your phone back to live there are follow
1). can you still remember your phone unlock code?
if the answer to this question is YES
then you will have to follow this instruction as guild line , put off your phone and remove the battery allow the phone to relax for about one hour 15 minute then fix up the battery back to it position switch it on and then punch in your code and click on ok button and always be very careful with your security code in any form.
solution no.
2). if then answer to the above question is NO then the way out to brig it back to live that you will have to unlock it with motorola soft ware with USB wire cord with your computer system
but if can't do this you will have to take it to a very good phone work shop for unlock please NOT flash.
thank you and thanks for using fixya.
5/30/2010 9:08:34 PM •
Motorola...
Answered
on May 30, 2010
