20 Most Recent LG VX5500 Cell Phone Questions & Answers
I dropped my phone on
there is circuit damage suggest a new stick phone so that you don't drop it any more
9/10/2017 1:52:35 AM • LG VX5500 Cell... • Answered on Sep 10, 2017
5answers
How can i recover pictures
Hi, thereYes, you have great possibility to retrieve the pics deleted or formatted from cellphone. Those pics are still in the memory of your phone just not visible, and pics data are waiting to be written over by new data. So from now on don't use your cellphone to take more pics.Then the best way to retrieve your deleted pics is to use some picture recovery programs. Recommended one is this photo recovery program. Here is the steps you may refer while retrieve your deleted pics from your phone memory.1. Download and install this photo recovery program on your computer. http://www.asoftech.com/apr/2. With your phone memory inserted, Under "My Computer", note the drive letter assigned to your phone's memory card (usually G: or H:).3. Start the program and select the drive letter that assigned to the memory, click "Start".4. Now the scanning process will start automatically to look for the deleted pictures. You will then get a list of all recoverable ones.5. Select the pictures you want and click "Recover" and you can get back deleted pictures from your phone successfully.
8/17/2016 3:52:10 AM • LG VX5500 Cell... • Answered on Aug 17, 2016
2answers
My screen on the lg vx5500 cell phone is making
Your problem is caused by the communication foil between the LCD and the mainboard of the phone. This foil contains a number of circuits that makes data transfer possible. The one or more circuits do not communicate anymore, the phone displays odd images.
1/13/2016 11:00:25 PM • LG VX5500 Cell... • Answered on Jan 13, 2016
2answers
How can i unlock my childs lg vx5500 lockcode
dial *22898 and it will set it as the last 4 digits of the phone number
4/6/2015 2:15:12 AM • LG VX5500 Cell... • Answered on Apr 06, 2015
I need a cdma driver for my LG VX5600 from Verizon
Hi... lg VX5600 cdma drivers (xp/vista/win7/win8) can be found at driverupdate us It will take 2 mins from you to install... I hope I have helped you... enjoy
11/15/2014 4:17:09 PM • LG VX5500 Cell... • Answered on Nov 15, 2014
0answers
Unlock or bypass code on an lg5500
yes you can try to do *22899 which will sometimes reset it to the last four of your phone number if this does not work, take it to the verizon store and ask a rep to hook it up to the PST machine and get the code for you, please find a knowledgeable rep to do this
2/9/2014 8:00:55 AM • LG VX5500 Cell... • Answered on Feb 09, 2014
Reset lg vx5500 to original factory defaut?
ok go to your menu, then go to tools. near the bottom, it says phone settings. select that and then go to security. select that, and enter your lock code (if you havent changed it since you have had your phone, its the last 4 digits of your number), then select restore phone.
9/1/2013 1:19:08 AM • LG VX5500 Cell... • Answered on Sep 01, 2013
manual
Can't bluetooth my lgvx5500 to apple 4s
try flash if or vist www.peony.tk
1/9/2013 8:54:04 PM • LG VX5500 Cell... • Answered on Jan 09, 2013
How to insert a simcard in lg
First All Check:1.Confirm whether same sim card is working in other h.s or not.2.Make sure the sim slot is o.k. only try these two.3.If all the above steps fails, check the SIM card connector pins for damage.if so try to get serviced. 4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.u can make it jumper mean u can fix this prob with out sim card is for this contact.5.take sim connector slight up by pin then cheak by inserting sim.6.hot air gun on sim i.c. then cheak it.Last Option:IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service& Sim Office and Get the Duplicate Sim Same Your No From Office OpratorProblem will Solved Quickly
10/28/2012 4:40:04 AM • LG VX5500 Cell... • Answered on Oct 28, 2012
I got my phone wet
Turn it off immediately and remove the battery. Put it inside a container and add uncooked rice to absorb moisture. Leave it there for 24 hours. After that, try turning it back on.If that won't work then it means there are pars that was damaged and you need to bring it to a repair shop.
10/11/2012 12:07:11 PM • LG VX5500 Cell... • Answered on Oct 11, 2012
2answers
Front screen and main screen are blank white.
When this happens it can be caused from a couple of things; I would recommend that you hard shock the device. You can do this by removing the battery while the device is powered on, leave it out for a minute, then reinstall the battery, and power the handset up. If this does not resolve your issue, then you are looking at a more serious handset issue.
9/5/2012 5:40:08 PM • LG VX5500 Cell... • Answered on Sep 05, 2012
3answers
My LG VX5500PP has a
hey hi buddy.....
the problem lies with the display,all you have to do is change the display and this is a very common fault in l.g mobiles............
please dont make file transfer from untrusted mobiles,virus can also harm ur mobile worstly.......
take care........good day
7/27/2012 8:19:23 PM • LG VX5500 Cell... • Answered on Jul 27, 2012
200 questions posted
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
VX LG
  • VX LG
Most Popular Question
need cdma driver lg vx5600 from verizon
  • Cell Phones
