20 Most Recent FUJIFILM Finepix A200 Digital Camera Questions & Answers
0answers
My fuji finepix a200 camera is showing protected
I'm going to show you a diagram that has to do with the card lock on the side of your memory card this slide is there to protect a card with images on it so it's not put back in the camera and formatted
Once you have unlocked the memory card you need to format the card to make it ready to accept new pictures from your camera. I hope you download your images first before formatting.
12/30/2010 12:48:42 AM • FUJIFILM Finepix... • Answered on Dec 30, 2010
Fine pix a 500 has zoom error after turn on
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
9/27/2010 5:06:54 PM • FUJIFILM Finepix... • Answered on Sep 27, 2010
My screen read 'card
Once you format a card, the pics are gone.
8/2/2010 9:24:59 PM • FUJIFILM Finepix... • Answered on Aug 02, 2010
I need a manual for my finepix a200 Help!!!!
You can download the user manual in PDF format by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
6/16/2010 6:43:53 PM • FUJIFILM Finepix... • Answered on Jun 16, 2010
I put new batteries in and the green light turns
Often I have found with modern digital cameras of all brans is that generic batteries no longer have the power to made them run, so even brand new generic batteries will not start the camera.
the solution is you always must buy the expensive brands or invest in a rechargeahle battery system for AA batteries, which mine takes the best. So try that out. I think u will find that money does make a difference
1/16/2010 10:24:30 AM • FUJIFILM Finepix... • Answered on Jan 16, 2010
I dropped my camera and the lens has tilted. My
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
1/8/2010 10:08:24 PM • FUJIFILM Finepix... • Answered on Jan 08, 2010
Zoom error ( stuck)
The lens is having a hard time retracting out that is why it is giving you that error. Make sure that your battery is fully charged and if it is, but still does not do any good, then do this little trick:
1. Hold the camera on your right hand with the lens facing the ground.
2. As you press the power on button, tap or hit the camera's base to your left palm. Do this several times.
Chances are, there could be a sand or granule of dust that got stuck on the sides of the lens, preventing it to retract properly.
Hope this helps.
11/27/2009 1:20:01 AM • FUJIFILM Finepix... • Answered on Nov 27, 2009
It says card not initialized. What do I do?
go to the erase menu and locate the "format" command. Perform the format on the card and the card should be free of any bad data so it is now ready to use. If, after formatting, the error is still present, you may have either a card or camera problem. If this fixes your problem, please rate the answer favorably. Thanks and best of luck.
11/17/2009 10:36:15 PM • FUJIFILM Finepix... • Answered on Nov 17, 2009
Focus error finepix hs10
About the HS10 autofocus problem, I discovered the cause and solution. It is a problem of camera design, and is caused by three screws securing the CCD sensor. These screws are not properly secured and the vibration eventually dropping. In two cameras with the same defect, the screws were loose. These screws adjust the sensor position relative to the lens and the sensor is loose when out of position not allowing proper focus. The solution is to disassemble the camera and secure the screws. These screws can not be too tight they need to be adjusted to position the CCD sensor correctly. The camera is difficult to dismantle because several wires are soldered. Care must be taken to discharge the capacitor of the flash, this may cause an electric shock and burn the camera board. Those who want to try the repair, follow the link to the service manual. http://elektrotanya.com/fujifilm_finepix_hs10_hs11_sm.pdf/download.html Milton Maenishi
1/5/2019 11:29:03 AM • Fuji FinePix... • Answered on Jan 05, 2019
I have a FinePix S1 and the display screen is not working. All other modes are working but no display
Many occasions LCD on camera display never fails but back light fails unless physical damage to LCD screen. Hold a torch to display when camera is on you will see faint(black and white) image means LCD is ok but back light is failed, it's replaceable but needs little skill to replace. Or replace full Screen with backlight. This is easy. Just remove back cover, remove display by loosening flex lock, put back new display carefully lock it holding flex with one finger. Please do not touch display flex contacts.
12/21/2018 2:22:04 PM • Fuji FinePix... • Answered on Dec 21, 2018
Finepix jz shutter not opening and zoom doesn't work
Time for a new camera, these are not repaired just exchanged, so the price is high, just replace it.
1/23/2017 8:54:23 PM • Fuji FinePix... • Answered on Jan 23, 2017
I am looking for lens-cap and case for my Fine Pix S1. Can you help?
Local friendly camera shop / manufacturer / Ebay
10/1/2016 8:24:47 PM • Fuji FinePix... • Answered on Oct 01, 2016
I am looking for a installation cd for my fuji finepix s1000fd camera - can l download one from the internet?
That should be possible - just Google the make and model, followed by the word software.
9/27/2016 2:11:08 PM • Fuji FinePix... • Answered on Sep 27, 2016
FUJIFILM Finepix A200 Digital Camera Logo
11 questions posted
Top Fuji Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Fuji Camera Expert? Answer questions, earn points and help others
View Most Popular
FinePix Fuji
  • FinePix Fuji
Most Popular Question
dropped camera lens tilted
  • Cameras
