20 Most Recent
Sony Cyber-shot DSC-T900 Digital Camera Questions & Answers
I got a sony cyber-shot dsc-t900 what is error
The error is: E 61 10 Zoom operations fault Inspect the lens block zoom reset sensor
Here are some things that are reported to work:
Reset the camera:
Home>Settings>main settings>Initialize>ok
If that doesn't work give the camera bottom a couple of slaps against the palm of your hand or strike the bottom against a book to knock the lens mechanism back in place. Be resonable with the force, you don't want to break the thing. It may take a half dozen wackings to get things settled.
Hope that helps,
BAX
Getting an error code c:13:01 on my sony t900 camera
“Memory Stick Duo” is unformatted.
“Memory Stick Duo” is broken.
“Memory Stick Duo” type error
The camera cannot read or write data
on the “Memory Stick Duo”.
Format the “Memory Stick Duo”.
Replace a new “Memory Stick Duo”.
Insert a supported “Memory Stick Duo”.
All above are solution for your quiry
How to change language from japanese to english
Using the menu you will need to go to the language link to select for english. Use your manula to find the timing to go around and click accordingly if the japanese language is not known to you. If you follow the menu and shift one by one to the other language menu , your puzzle will be solved. So memorise and go on, the tip is study the number of links/subject in the open window and each window wil have specific number of titles so get to the language link . Good day
When I slide the cover down to turn the camera on,
You've got nerve asking me to share my solution with FixYa for free, when you are going to charge me for support and to ask the question. Here's how I fixed it. I asked Sony (for free) and they gave me support (for free). Bugger off!
Hi My name is James
Hello
Thank you for using FixYa for your problem
Your Memory Card is faulty. It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts. or just get a new card
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Need usb transfer cable code or number for a sony cybershot n50
I believe you are looking for a USB transfer cable for your Sony Cybershot N50. I found a replacement USB camera transfer data sync charging cable cord for Sony Cybershot Cyber-Shot DSCH200, DSCH300, DSCW370, DSCW800, DSCW830, DSC-H200, DSC-H300, DSC-W370, DSC-W800, DSC-W830 digital camera on Amazon . This cable is compatible with several Sony Cybershot models, including the N50. The cable is priced at $7.95 and comes with a 30-day return policy.
Amazon.com: Replacement USB Camera Transfer Data Sync Charging Cable Cord for Sony Cybershot Cyber-Shot DSCH200, DSCH300,DSCW370,DSCW800,DSCW830,DSC-H200,DSC-H300,DSC-W370,DSC-W800,DSC-W830 Digital Camera (Black) : Electronics
1/23/2024 10:01:12 PM •
Sony Cameras
Answered
on Jan 23, 2024
