20 Most Recent Ski-Doo 2004 MX Z Renegade 800 H.O Questions & Answers
I have a 1991 skidoo tundra. And I have no spark. I changed the cdi box and swapped coils. What is the gap for the magnetic pick up also how do I test the magnetic pick up?
When in a pinch I have used a business card to set the gap, remember close will advance timing further will retard timing, unless you are a long way from the flywheel gap most likely not the issue but will affect spark intensity. Most likely bad pickup coils or weak magnets which requires flywheel replacement.
3/4/2018 5:39:41 PM • Ski-Doo 2004 MX... • Answered on Mar 04, 2018
Engine shuts off when steering is at full lock
I guess im not understanding what full lock is,but check around your steering column for any bare wires that could short out and kill the engine. Its a common problem.
7/25/2016 1:55:30 PM • Ski-Doo 2004 MX... • Answered on Jul 25, 2016
Shuts down after warm will start after it cools
Change your external coil.
3/2/2015 1:58:36 PM • Ski-Doo 2004 MX... • Answered on Mar 02, 2015
How to tighten belt
need to tighten or replace blower belt troy bilt snow king 9528
11/28/2014 7:28:24 PM • Ski-Doo 2004 MX... • Answered on Nov 28, 2014
How to tighten belts on a vermeer rebel 5410 round bailer?
There is a Bold that pulls it back and make sure you do both sides evenly or you will wear belts..
11/21/2014 3:06:29 PM • Ski-Doo 2004 MX... • Answered on Nov 21, 2014
Drive belt problems
They go bad in time... Check your alaignment and tension,
10/2/2014 4:49:34 PM • Ski-Doo 2004 MX... • Answered on Oct 02, 2014
How to tighten drive belt on gt262?
It has a centrifugal clutch so nothing to tighten. Its likely your clutch mechanism that is not working properly. what are your symptoms
6/10/2014 7:02:13 PM • Ski-Doo 2004 MX... • Answered on Jun 10, 2014
How to adjust a kgro riding mower deck belt
Check this link for information on your KGRO mower
5/31/2014 8:53:57 PM • Ski-Doo 2004 MX... • Answered on May 31, 2014
How do i tighten drive belt on gt262
many of the JD's have an idler pulley on that belt that is mounted to the tractor frame in a slotted hole (near the engine). You loosen the pulley retaining nut and then slide that pulley (and it's mounting hardware) in the slot, to adjust belt tension.
5/31/2014 7:13:04 PM • Ski-Doo 2004 MX... • Answered on May 31, 2014
How do you tighten a timing belt on a 02 eclipse?
Hi Holly, I have this video for you on how to do it (same way on your machine). Hope it helps.
4/26/2014 6:34:23 AM • Ski-Doo 2004 MX... • Answered on Apr 26, 2014
I have a 2006 Polaris 900rmk snowmobile it keeps overfueling at idle I believe it is one of the injectors on pto side not sure which one of the 2 affects your idle any ideas?
they both can repair manual show how to trouble shoot --------https://snowparts.ru/manuals/Polaris%20Trail%20600-900%20RMK%20Switchback%20Service_Manual_2005.pdf
1/10/2023 1:06:51 PM • Winter Sports • Answered on Jan 10, 2023
No spark on 02 ski doo legend
You have a bad coil or wire.
1/3/2023 2:25:15 AM • Winter Sports • Answered on Jan 03, 2023
2answers
Spark plug gap on a 2006 Polaris 700 Classic
It depends on the brand of spark plug you are using. https://www.google.com/search?q=2006+Polaris+700+Classic+spark+plug+gap ..
12/18/2022 3:53:35 PM • Winter Sports • Answered on Dec 18, 2022
2answers
Wearfit 2.0. Why can't I bind to my iPhone?
Discord users facing issues like How To Fix Discord Not Opening so just make a call on Discord Customer Support 1-802-618-6092 anytime and experts are there on Discord Live Chat to help you 24*7 . Need any kind of guidance to fix the Discord issue so just make a call on Discord customer Service 1-802-618-6092 anytime and fix issues, a helpdesk is there to help you 24*7
2/24/2022 9:59:23 AM • Winter Sports • Answered on Feb 24, 2022
2003 Ski-Doo Grand Touring 550 Fan. All of a sudden I have no spark! What could be the problem?
kill switch --ign switch--cdi--magneto--broken wire --etc https://ski-doo-snowmobile.brssm.com/ https://www.snowmobilerepairmanual.com/ski-doo-repair-manual/
1/16/2022 5:08:05 PM • Winter Sports • Answered on Jan 16, 2022
Skandic Skidoo. How do I take out a battery that is located underneath the seat of a Skandic Skidoo
Question edited for clarity. Question moved from Seat Cars (Spanish car maker and pronounced See-at) to Snowmobiles Category. The are videos and text based articles. The best bet is to fit pigtails to the battery and had a plug for a battery maintainer. You never have to remove the battery, and you never have to worry about it it not being charged. https://www.google.com/search?q=skandic+skidoo+remove+battery ..
1/15/2022 10:33:14 PM • Winter Sports • Answered on Jan 15, 2022
2012 Switchback adventure 600
MAYBE IT NEEDS SOME OIL ADDED
1/4/2022 7:51:27 PM • Winter Sports • Answered on Jan 04, 2022
3answers
What types of waxes are used in cross-country skiing?
There are four different types of waxes that are used: waxtapes, glide waxes, klisters, and kick waxes.
6/25/2021 3:58:02 PM • Winter Sports • Answered on Jun 25, 2021
1991 Polaris Indy 500 Classic. How do you remove the chain case? It seems to be holding on the top?
I fixed the question and put you in the Snowmobile category Video instructions here https://www.google.com/search?q=1991+classic+500+replace+chain ..
6/4/2021 3:46:08 PM • Winter Sports • Answered on Jun 04, 2021
2007 Arctic Cat F1000. Why does it keep stalling while being ridden?
It could be many different items, choke stuck, ignition switch etc. but more importantly have you taken care of your recall? https://www.cpsc.gov/Recalls/2017/Arctic-Cat-Recalls-Snowmobiles
4/29/2021 5:05:37 PM • Winter Sports • Answered on Apr 29, 2021
Ski-Doo 2004 MX Z Renegade 800 H.O Logo
44 questions posted
Top Ski-Doo Winter Sports Experts
Arnie Burke
Arnie Burke
john h
ADMIN Andrew
ADMIN Andrew
Are you a Ski-Doo Winter Sport Expert? Answer questions, earn points and help others
View Most Popular
MX Z Renegade 800 H.O Ski-Doo
  • MX Z Renegade 800 H.O Ski-Doo
Most Popular Question
1991 skidoo tundra no spark changed
  • Winter Sports
