20 Most Recent Arctic Cat 2009 CrossFire 8 Sno Pro Questions & Answers
2010 crossfire 800 had a small back fire stalled wouldnt start for 30 min ran for 5 miles next day ran 3 miles than small back fire stalled started 20min later run for 5 miles took home wont start
Sounds like it was starving for fuel. First thing to do is check your fuel pump pressure with a gauge. Try sprayinf a little starting fluid into the throttle body to see if it will start. If it does, then you know its a fuel problem.
2/27/2019 5:21:29 PM • Arctic Cat 2009... • Answered on Feb 27, 2019
Where can i find the remote control and instruction manuel
from artic pro
7/3/2015 3:52:50 AM • Arctic Cat 2009... • Answered on Jul 03, 2015
How to replace spark plugs
Spark Plugs are screwed into the Top of the Head. Do not over tighten, applying anti-sieze will not hurt but normally will not be an issue to begin with.
12/1/2014 12:00:40 PM • Arctic Cat 2009... • Answered on Dec 01, 2014
600 triple engine bogs
There's a number of things it can be first check throttle switch bypass all switches at the base it it still bog stator
3/3/2015 11:47:50 AM • Arctic Cat... • Answered on Mar 03, 2015
Atv artic cat 1000 gage problem..
Check for burnt wires around the hood hinge.
10/20/2014 4:18:06 PM • Arctic Cat... • Answered on Oct 20, 2014
2012 arctic cat F5 oil lite comes on when oil resevior is full
Sensor is defective.
10/20/2014 4:12:56 PM • Arctic Cat... • Answered on Oct 20, 2014
Wont start when cold
RE adjust the choke.
10/2/2014 5:24:47 PM • Arctic Cat... • Answered on Oct 02, 2014
No electric no lights or spark pull start
Inspect and test your stator plate.
10/2/2014 4:58:55 PM • Arctic Cat... • Answered on Oct 02, 2014
2011 1100 cc Arctic Cat that stalls when coming to a stop. Doesn't do it all the times. Then starts right back up. Also backfires once in a while when you let the gas off.
The back fireing is common,but check the bushings in your drive clutch,when the inner goes bad,the clutch will not totally disingauge causing the sled to stall.
9/29/2014 7:16:11 PM • Arctic Cat... • Answered on Sep 29, 2014
2002 arctic cat 509 track clicking noise near fron sprocket
If the sled is picked,look for any torn ones that may be hitting the tunnel. Or take a look at your drive shaft berrings.
9/29/2014 7:12:19 PM • Arctic Cat... • Answered on Sep 29, 2014
2008 90 atv
If you dont have a fuel problem,change the external coil.
9/29/2014 7:10:34 PM • Arctic Cat... • Answered on Sep 29, 2014
1997 580 ext efi revs to 8000 rpms than drops and stays at 7000 rpms
Take a look at your drive clutch spring,is may be tired or broken.
9/29/2014 7:08:33 PM • Arctic Cat... • Answered on Sep 29, 2014
Charging system problem 1994 pant era
Sounds like you have a short in your wireing harness. Look by the brake caliper.,also make sure the voltage regulator is tight.
9/29/2014 7:01:13 PM • Arctic Cat... • Answered on Sep 29, 2014
Wildcat trail tranny jumping out of gear
You may have a bad drive shaft berring.
9/29/2014 6:57:12 PM • Arctic Cat... • Answered on Sep 29, 2014
94 artic cat zr580,wont move revs up to 4500rpm, idles have bypassed all switches,new primary coil,
If your drive clutch is ingaging take a look at your chain. It may have broke.Common problem!
9/29/2014 6:56:18 PM • Arctic Cat... • Answered on Sep 29, 2014
Arctic cat problems
Sounds like you have one of a few issues: Clogged Main Jets Cut Off on the Throttle restricting your running Compression Test the Engine and see that the PTO Cylinder is at least a 110-120 Compression and the split between is not more than 10 psi
2/13/2014 1:17:41 AM • Arctic Cat... • Answered on Feb 13, 2014
I have a 2006 Polaris 900rmk snowmobile it keeps overfueling at idle I believe it is one of the injectors on pto side not sure which one of the 2 affects your idle any ideas?
they both can repair manual show how to trouble shoot --------https://snowparts.ru/manuals/Polaris%20Trail%20600-900%20RMK%20Switchback%20Service_Manual_2005.pdf
1/10/2023 1:06:51 PM • Winter Sports • Answered on Jan 10, 2023
No spark on 02 ski doo legend
You have a bad coil or wire.
1/3/2023 2:25:15 AM • Winter Sports • Answered on Jan 03, 2023
2answers
Spark plug gap on a 2006 Polaris 700 Classic
It depends on the brand of spark plug you are using. https://www.google.com/search?q=2006+Polaris+700+Classic+spark+plug+gap ..
12/18/2022 3:53:35 PM • Winter Sports • Answered on Dec 18, 2022
Arctic Cat 2009 CrossFire 8 Sno Pro Logo
6 questions posted
Top Arctic Cat Winter Sports Experts
Kardoc
john h
Arnie Burke
Arnie Burke
Are you an Arctic Cat Winter Sport Expert? Answer questions, earn points and help others
View Most Popular
Crossfire 8 Sno Pro Arctic Cat
  • Crossfire 8 Sno Pro Arctic Cat
Most Popular Question
2010 crossfire 800 small back fire
  • Winter Sports
