20 Most Recent
Honda 2008 AquaTrax F-15X GPScape Questions & Answers
Oil problem on a 1996 50 hp Honda outboard
It's a little vague . What's the problem ? Over heating , fuel in oil , water in oil? Over heating will be a water pump problem , water in your oil is a bad head gasket, fuel in oil is passing rings . Honda's are great engines but they must be broken in properly .
Honda 50 marine outboard stalls at high revs
Those systems have an injector + mechanical pump... check the fuel line to see if its getting a restriction . And the filters.. If not there check the float bowel located on the right side ( standing behind the boat looking forward. It's located under the air intake...if it isn't allowing enough fuel in you'll stall. Honda is a good engine but the engineers got lazy when they left half of the system efi and half mechanical.
