20 Most Recent
Cadet Manufacturing CADET SL Series Small Room Heater Wall Heater Heater Assembly and Grill Only 120 Volts 1000 Watts (... Questions & Answers
I just need a wiring diagram---with a thermostat--
grainger has them- home depot. wire is easy wire one side straight to 1 wire on in coming power the other side use your thermostat to break curcit ie wire into stat out of stat to voltage
9/22/2019 8:38:58 AM •
Cadet...
Answered
on Sep 22, 2019
Cub cadet lt1040. won't start. new battery.
I had the same problem the starter was the problem, found the stater will engage by itself not sure why but think it could be the wireing, or a swich. also check the solenoide it could be bad if the starter is bad.
6/12/2016 3:20:23 PM •
Cadet...
Answered
on Jun 12, 2016
Heater stopped working after my daughter was
heaters have a diode inside and it must of triggered it and perhaps blew it out if the reset doesnt work after a couple more times put it in the coll and see if it after over nigth set out will work the nest day keep me posted
1/25/2010 2:32:11 AM •
Cadet...
Answered
on Jan 25, 2010
LT 1040 dead as a door nail
Try checking the fuse.Sometimes hitting a bump or moving around on the seat will cause a current surge.
5/1/2009 6:19:27 AM •
Cadet...
Answered
on May 01, 2009
Domestic hot water works but no hot water to baseboard heat
If its a one story house, the system pressure should be somewhere around 10 to 12 psi. There should be a PRV (pressure reducing valve) on the domestic water line supplying make up water to the boiler. The shut off valve in that line should be in the open position unless the prv leaks through and slowly overpressurizes your system to the point of tripping the pop-off valve. If so, then the manual shut off should be kept closed then opened only to boost the pressure up a bit in the system. It kinda sounds like you are suffering from low system pressure.
If there is a vent or vents in the system, try bleeding them into a coffee cup and you may find it sputtering air/water mixture. Bleed them until you have full water flow and make sure you keep approximately 10 psi in the system.
12/30/2014 12:46:59 AM •
Cadet...
Answered
on Dec 30, 2014
I have a cadet wall heater, the orange light comes on, i have to shut it off and turn it back on. It is blowing heat.
There is a little sensor called a 'flame sensor' that is inserted into the actual flame. Its only job is to complete a grounding circuit on the control board actually through the gas flame... By the description of your problem, it sounds like it either has oxidation on its surface OR the physical connections at the flame sensor itself or where it plugs into the control board have just enough oxidation to imhibit the signal from the flame sensor.
I would suggest calling the service center to have a tech look at it.
12/30/2014 12:36:20 AM •
Cadet...
Answered
on Dec 30, 2014
