20 Most Recent GE JGBP28 Gas Kitchen Range Questions & Answers
I HAVE A GE JGBP28 RANGE THAT THE OVEN WILL NOT
Open sensor circuit or intermittent sensor connection. First you need to check the sensor, to test it disconnect power, pull the range or oven out then take off the back cover. Once off, you should see the two small wires that are from the sensor and you need to disconnect them (some have a plug but if you have to cut the wires). Now using your ohmmeter , measure resistance between the wires going to the sensor. It should be somewhere between 1050 and 1150 ohms. Note that this test should be done while the oven is at room temperature. If the sensor is open (or not within that range) replace sensor.. you did this but have seen bad sensors new, if not check the wiring between sensor and control. If you don't find any loose connections, the problem may be in the control board but the sensor is much cheaper, so testing with a ohmmeter and cking wiring will totally eliminate that. Sensors and control boards can be purchased at AppliancePartsPros.com or Repairclinic.com. they who I use. they have online chat and 800# to talk with a tec. if needed before ordering or install questions. Hopefully tis a bad new sensor or loose wire connection. Hope this helps a little.
12/31/2017 9:10:20 PM • GE JGBP28 Gas... • Answered on Dec 31, 2017
I have an 3 way camping fridge but when using the
looks like a faulty pressure valve qualified gas fitter needs to check over the gas part of the fridge
4/17/2017 6:52:36 AM • GE JGBP28 Gas... • Answered on Apr 17, 2017
manual
Kitchen aid convection range bake igniter stays on
Pull the igniter out and see if there is a short to ground on the wire. If none is found, replace the igniter. Here is the part to order.
1/21/2013 7:39:18 AM • GE JGBP28 Gas... • Answered on Jan 21, 2013
0answers
I have a GE XL True Temp gas range/oven. None of
your stove must be plugged in for the auto-pilot to work .do you hear a ticking noise when you turn on a burner?
6/5/2011 6:23:10 PM • GE JGBP28 Gas... • Answered on Jun 05, 2011
My gas burners light, but all of sudden my oven
hi
replace the lamp
1/10/2011 1:21:09 PM • GE JGBP28 Gas... • Answered on Jan 10, 2011
GE Range Oven Model# JGBP28BEA6WH: Wiring to oven
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
8/13/2010 9:41:36 PM • GE JGBP28 Gas... • Answered on Aug 13, 2010
Oven won't light
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
7/30/2010 4:31:51 AM • GE JGBP28 Gas... • Answered on Jul 30, 2010
GE Gas Oven does not turn on for Bake but turns on Broil&Clean
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
7/15/2010 4:09:41 AM • GE JGBP28 Gas... • Answered on Jul 15, 2010
Oven not coming on
heatman101
5/6/2010 12:04:44 PM • GE JGBP28 Gas... • Answered on May 06, 2010
I spilled water on the range. 3 burners have blue
you need to clean out that particular orfice with an orfice wire cleaner available thru a welders supply or appliance parts store as the water minerals have dried and partially plugged the orfice tube and it can't get the right amount of air to burn the gas completely
4/25/2010 12:46:42 PM • GE JGBP28 Gas... • Answered on Apr 25, 2010
Burners work, broiler works but oven will not
The most common problem with gas ovens is the failure of the ignitor...
Check out this tip that I wrote...
heatman101
4/13/2010 2:45:36 AM • GE JGBP28 Gas... • Answered on Apr 13, 2010
GE JGBP28 Gas Kitchen Range Logo
100 questions posted
Top Kitchen Ranges Experts
Steve Sweetleaf
Steve Sweetleaf
ZJ Limited
ZJ Limited
Are you a Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
GE Kitchen Ranges
  • GE Kitchen Ranges
Most Popular Question
gas burners light but all sudden oven
  • Kitchen Ranges
