20 Most Recent
GE JBP64 CleanDesign Electric Kitchen Range Questions & Answers
Burner will not turn off
I would first check the infinite control switch (#WB24T10029) the part the knob slips onto. The next thing I'd check is the erc (#WB27T10231) control board. Hope that is helpful!
3/8/2009 8:51:29 PM •
GE JBP64...
Answered
on Mar 08, 2009
Stopping self cleaning
Press the clear button. If it has already heated up it will need to cool down before the door lock will release it is a safety feature so you don't burn your eyebrows off!. Hope that helps.
1/15/2009 5:40:40 PM •
GE JBP64...
Answered
on Jan 15, 2009
Replaceing glass top on a stove
The top can be replaced but it is expensive. Your range is less than a year old call a local servicer to see if there may be warranty available to cover this problem it may not cost you anything. Good luck.
1/15/2009 5:36:03 PM •
GE JBP64...
Answered
on Jan 15, 2009
The display doesn't work on my ge model JBP21GS1WH, however the burners work fine, is there a reset or something?
No reset found in the manual. You can try this and hope it works..
Turn off the circut Breaker to the stove for 5 minutes to see if it resets. Checking around the net I've only found
"Item Discontinued"
- The part is no longer sold by the manufacturer.
- The manufacturer does not stock any substitute parts to replace this one and therefore, unfortunately, we cannot obtain or recommend a substitution for this part.
- We cannot obtain the part through any other means.
Darn..
My ge stove is beeping and says bad line I unplugged and plugged it back in and still does it
If your GE stove is beeping and displaying the message "bad line," it typically indicates an issue with the electrical power supply. Here are a few troubleshooting steps you can try to resolve the problem:
- Check the Power Supply: Ensure that the stove is properly plugged into a functioning power outlet. Verify that there is no issue with the circuit breaker or fuse that supplies power to the stove. You may need to reset the circuit breaker or replace a blown fuse if necessary.
- Inspect the Power Cord: Examine the power cord for any signs of damage, such as cuts, fraying, or exposed wires. If you notice any issues, it's advisable to replace the power cord with a new one to ensure safe and reliable operation.
- Test the Outlet: If possible, try plugging the stove into a different power outlet to see if the "bad line" message persists. This step helps determine if the issue lies with the stove or the electrical supply in your home.
- Contact a Professional: If the problem persists or if you are unsure about performing further troubleshooting steps, it's recommended to contact a qualified appliance repair technician. They can diagnose the specific issue with your GE stove and provide the necessary repairs or replacements.
My 15 year old GE Gas oven shoots flames after replacing regulator/valve.
This issue could be caused by the oven regulator valve not being set correctly for the altitude and fuel source. I'd suggest double-checking that the regulator is properly adjusted to the altitude and fuel source. Additionally, you may want to check the oven igniter and burner for proper operation and make sure the correct model and size of burner is installed. If you have any further questions or need help, please feel free to reach out.
