20 Most Recent
GE Monogram ZEU30R Electric Cooktop Questions & Answers
GE Monogram f160 error code?
When an "F" and a number appear in the display and the cooktop beeps you have a function error code.
Touch the CONTROL LOCK pad.
Disconnect power to the cooktop and then reconnect.
If an F-code appears again, call for service.
Ge monogram cooktop model#zeu30rsf1ss error
Hi There
I have found the codes that you need and hope this helps you.
F1
Stuck touch pad
Usually means that either the touch pad or the oven control (also called
clock or ERC) is defective and needs to be replaced. If this fault code
cannot be cancelled, replace the oven control (also called clock or ERC),
touch pad, or both.Thank You for writing to fix ya.
Best Regards Richard
How to change wb30t10062
remove the cook top from the counter and the remove the glass top, several screws around the edge of box. the lift top and you have access to the elements.
My cooktop is showing f156
You haxe a flmction error code. X,_rite down the "F:- - -" and
touch the _) (CONTROl, I,OCK) pad. Disconnect power to
if this doesnt work then you would have to call for a technician looking like you might have a problem with the control if you have any further questions message me back Thanks Rick if you cant unplug your unit shut off the breaker for 5-7min
