20 Most Recent GE 30 in. Profile JGP932 Gas Cooktop Questions & Answers
Ge profile cook top snapping
They are not that hard to replace and you can easily buy the part online...
Here is a tip about how to buy appliance parts online.
How to Buy Appliance Parts Online
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
5/12/2015 12:49:29 AM • GE 30 in.... • Answered on May 12, 2015
manual
manual
6 yr old ge profile cooktop. L Front burner
Don't buy GE ****
11/8/2011 3:05:25 PM • GE 30 in.... • Answered on Nov 08, 2011
I have a glass 4 gas burner stove top and cracked
Yes the glass is replaceable, you will have to order a new one, and you could do so through an appliance parts store. They can even put it in for you.
3/22/2011 6:38:21 PM • GE 30 in.... • Answered on Mar 22, 2011
2answers
Gas on one cooktop will not ignite--just keeps
This is very common....we should do this first before tearing it apart and start checking components
If that will not correct the issue,you will need to watch the next video to show you just how the stove works,and what we will be checking.
Click on the link http://www.youtube.com/watch?v=kSS-w3-Jlk4
There is a schematic located most probably under the top of the stove that you will need when we start checking parts.
You will need a volt meter and be able to read a schematic.
Please keep me posted.
Keith
3/9/2011 2:10:44 AM • GE 30 in.... • Answered on Mar 09, 2011
Piezo igniter won't quit
Possible stuck burner switch or failed spark module. Unplug unit. Remove wires from burner switches at module and plug back in. If it starts sparking, replace module. If it stops, then replace switch harness.
1/18/2011 5:00:05 AM • GE 30 in.... • Answered on Jan 18, 2011
I have a ge Profile cooktop that clicks when I try
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
8/30/2010 12:32:53 PM • GE 30 in.... • Answered on Aug 30, 2010
My glass top has a broken in the corner on my
I'm sorry to hear this. you can get just the top, but your lookingat somewhere between 300-700 dollars just for the glass. also this is not a common part and will probably be back ordered, so you'll be looking at a wait of 2-5weeks for the part. you can change it yourself but due to the cost of the glass I would have a service company change it so that if it breaks while changing they will have to pay for a second one and you wouldn't be stuck having 2 broken glasses
4/23/2010 7:56:24 PM • GE 30 in.... • Answered on Apr 23, 2010
Will a 4 burner cooktop work on a ten gallon
no.....check the unit if is low or high presure b4 u replace or buy a new regulator.....
1/19/2010 2:55:14 AM • GE 30 in.... • Answered on Jan 19, 2010
One igniter won't work right on my gas cooktop.
If you're not getting the ignitor sparking (you should hear it) when you turn the burner knob on for that burner, it could be that either the ignitor is dirty or caked with some gunk and needs to be cleaned.
The other issue could be that the ignitor is faulty and needs to be replaced. If you want to confirm a faulty ignitor before ordering a new one, you can swap it out with one of the other ignitors on the cook top. Be sure to unplug the cook top from the outlet thou, to prevent getting a shock, as those little sparkers can give you a pretty good jolt!
Just remove the grates and burners to get at the ignitor for cleaning it. To get at the ignitor, youll need to go under the cabinet or counter that the cooktop is installed on in order to remove the ignitor and swap it with one of the other ones. You'll see that these are held in place with a retaining clip you can remove with a flat bladed screwdriver, etc.
If you find that the one that isn't working is faulty, you can order one from your local appliance service store, or get one online. www.searspartsdirect.com lists parts for almost every appliance there is, just enter in the full model number to get a parts list, etc.
Hope you find this Very Helpful and best regards!
9/9/2009 4:50:37 AM • GE 30 in.... • Answered on Sep 09, 2009
Ignition will not stop clicking...
Did you clean your stove recently? If the switches under the burner knobs get wet they will cause the burners to click. Unplug the unit or shut off the power for a day. Once the swithes dry, it should work normal.
5/5/2009 4:59:54 PM • GE 30 in.... • Answered on May 05, 2009
Gas is flowing to all, but the front left burner will not ignite.
hello, it sounds like your Spark switch went out its located just under you knob to check it you'll have to open the top of your range and look at the one for your bad burner and see if thairs any burn or black marks on it that'll be a dead give away to it being bad or going out, what probably happened is that the water caused a ground and burnt it out. if that's the case and you need to order a new one here's a web sight were you can order the part from all you have to do is put in your ranges part # and click on the things on the left side of the page to find the exact part for your appliance.
http://www.repairclinic.com/
3/29/2009 3:21:33 AM • GE 30 in.... • Answered on Mar 29, 2009
Replacing Grill module with gas burner on GE Gas cooktop (PGP990)
You can't modify gas appliances.
9/27/2023 5:42:09 PM • GE Cooktops • Answered on Sep 27, 2023
Wiring for GE Cooktop 1960s
I have an early 1970s GE, and we keep saying when it breaks down, we will replace it, but apart from replacing elements, it just goes on and on. Unfortunately, neither of your numbers give results. There should be a plate near the power lead that has the details and some have a parts manual and wiring diagram in the rear of the console if it has one. https://www.google.com/search?q=GE+82212+cooktop https://www.google.com/search?q=GE+YT123887L+cooktop ..
9/17/2023 10:38:35 PM • GE Cooktops • Answered on Sep 17, 2023
2answers
Fuse location on GE Profile PP975S Cooktop (If there is one)?
Question edited for clarity. There is no fuse, the loads are too great. The Service Manual is in the link. Check the Control Lock on Page 11. https://ja.safe-manuals.com/source/pdf/adea1af72b5b020af66562d603ff2631 https://www.google.com/search?q=ge+pp975s+fuse+location ....
12/25/2022 7:57:23 AM • GE Cooktops • Answered on Dec 25, 2022
How do you remove only the maintop cover of a GE JGP963 gas cooktop? I need to replace a part, but can't remove the maintop even after unscrewing and removing every burner.
It is a gas appliance. From the installation manual. Installation and service must be performed by a qualified installer, service agency or the gas supplier. It needs to come out as there is almost certainly fixings from below. Screws on the burners, only hold the burner rings down. The installation manual doesn't say how the top comes off, just how to install. No Service Manual for it. https://www.manualslib.com/manual/57348/Ge-Jgp630.html?page=1#manual ..
12/1/2022 8:15:10 PM • GE Cooktops • Answered on Dec 01, 2022
F152 error GE Monogram electric cooktop
Take out the right front burner and use your multimeter to check it for continuity. Only then can you be sure that the error code isn't lying to you. It is my guess, that with an error message so specific, that if no burners are working, it is not the front right burner at all. Hands on testing is the only way to be sure. F152 means the right front burner has failed, the sensor in it is bad, the burner will need to be replaced.
error code F152 ' Appliance Video
The element is $225.00 so it is not something to change on a guess. Full testing procedure here, or call for a Service Engineer. https://www.appliancepartspros.com/answers-for-ge-element-radiant-lt-wb30t10080-ap3188020-question-148609.html ..
3/20/2022 6:27:28 PM • GE Cooktops • Answered on Mar 20, 2022
Where can I get replacement control knobs for my GE JGP636 gas Cooktop
do an online search or if a repair shop in area order from them
1/22/2022 1:33:42 PM • GE Cooktops • Answered on Jan 22, 2022
GE 30 in. Profile JGP932 Gas Cooktop Logo
15 questions posted
Top GE Cooktops Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a GE Cooktop Expert? Answer questions, earn points and help others
View Most Popular
GE Cooktops
  • GE Cooktops
Most Popular Question
glass 4 gas burner stove top cracked
  • Cooktops
