20 Most Recent
Dayton 511 Utility Heater Questions & Answers
My heater wont light it ust blows fuel from the
it means your glow plug isn't "glowin", electrical problem, are you mechanically inclined, or do you still have manufacturer's warranty? or did u try to run diesel in your kerosine-only heater?
DAYTON 150,000 HEATER FAN
One paddle on rotor may be hanging up. Take end cover off clean the rotor and paddles and set the clearage to .0010 .It should work all right. Ken's RepaIR
FAN GET STUCK
There is a vane type air pump on the back of the blower motor. It is made of carbon material. It is possible that the pump has broken and is stopping the motor from turning. Take the back plate off of the motor to access the air pump and check it.
I may need a replacement air pump for this heater
Before you buy a pump, check the filter cover for cracks. You can make a soap solution using dishwashing liquid and a little water to spray on the cover. Turn the heater on and look for bubbles coming out of the cover. Check the model # and go to
www.desatech.com. Click on construction heaters and from the drop down menu click on your model #. You can get the part #'s from the manual. Go to
www.partsfor.com and use the part #'s to order the parts you need.
Replacement parts
Dayton was made by Desa. desaint.com has parts or run search for reddy heater parts the photo cell should be the same.
