20 Most Recent GE GSS22JFMWW Side by Side Refrigerator Questions & Answers
2answers
Ice Maker works but water dispenser does not.
tank can freeze up check timp the tank is in the food compartment at the bottom in the very back
6/15/2015 3:35:56 PM • GE GSS22JFMWW... • Answered on Jun 15, 2015
0answers
Ice at bottom of freezer
Hi Lee, you must remove the back panel of the freezer to access the drain.it has 4 screws holding it in place. Good luck
11/24/2013 3:13:52 AM • GE GSS22JFMWW... • Answered on Nov 24, 2013
Just got the refrigerator and set it up. The
Check if power is coming to the socket, if yes check plug fuse, if ok check if reset button on circuit board has tripped, try after resetting
10/17/2013 7:12:57 AM • GE GSS22JFMWW... • Answered on Oct 17, 2013
My refrigerator is stuck in defrost mode
If your refrigerator is a few years old it may have an electromechanical timer to control the defrost cycle. With age and/or lots of dust the timer motor can wear out or the switch contacts can get stuck. Behind the grill below the door there should be a small black box with several wires coming out of it. On the front of the box there is a small (dime sized) round disk with a slot in it. This is the defrost timer, a 24-hour clock mechanism which switches the cooling unit off and the defrost heaters on for 15 or 20 minutes every 24 hours (approximately). Insert a small insulated screwdriver into the slot and turn it slowly clockwise until you hear a click. The compressor and fan(s) should turn on (if they aren't running already) and the defrost heaters should turn off. If you continue turning the timer disk you should hear another click and the compressor & fans will shut off and the heaters turn on. Stop turning the disk at this point. Wait a couple of minutes and then turn the disk a few degrees farther (5 degrees represents about 20 minutes). You should hear a click and the compressor starting up again. If there is no change and the heaters still seem to be on, then you may need to replace the timer (it should unplug from the wiring harness). A Home Appliance Parts store should be able to provide you with a compatible replacement timer.
11/19/2012 3:49:06 AM • GE GSS22JFMWW... • Answered on Nov 19, 2012
GE REFRIG GSS22JFMAWW Damper STAYING CLOSED
the damper door assy located in the upper left corner just left of the water filter of the refrigerator compartment probably has a broken damper door shaft on one side and has jammed in this position,this is very common with G.E. SxS I have glued these shafts back together with good success,but you may want to just replace it
5/8/2012 12:57:59 PM • GE GSS22JFMWW... • Answered on May 08, 2012
Freezer will not freeze
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
9/14/2011 2:55:45 AM • GE GSS22JFMWW... • Answered on Sep 14, 2011
Side by side refrigerator stopped
Sounds like the defrost timer/board may be hanging up....
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
3/24/2011 1:26:22 PM • GE GSS22JFMWW... • Answered on Mar 24, 2011
The water dispenser will not work although the
The water line is not blocked,but the problem is water valve.At the back of the ice maker there is a water valve.This water valve has two section holes.From one hole the water passes to ice maker tray and from other hole the water passes to water dispenser.Si in your case this valve is working properly for ice maker section but its not working for water dispenser.Its a twin valve.This valve has to be replaced.The other possibility is water line blocked,but if you are confirmed that water line is clear then replacing water valve will help to solve the problem. ------------- To see how this valve looks.Please see the fig below:--- helpmech_65.jpg
In the fig you can see the two sections of one valve.The dark blue and dark brown.In your case the Blue section of valve is running and functioning properly,but the brown section is not working properly or vice versa.In any case this valve needs to be replaced.The valve is located at the back of the ice maker section. ---------- To order this valve .Please click on the link below:--- http://www.repairclinic.com/PartDetail/Water-Inlet-Valve/880070 -------------- If you require instructions for part disassembly to locate and remove the valve.Please click on the link below:--- http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http://c.searspartsdirect.com/lis_png/PLDM/G0311240-00002.png ------------ Part number 800 is valve. ------------ Also for complete disassembly of ytour refrigerator.Please click the link below:--- http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Refrigerator-Parts/Model-GSS22JFMDWW/0432/0165000?searchedModel=GSS22JFMWW&blt=11 ----------- This will help.Thanks.Helpmech,.
2/7/2011 6:10:02 PM • GE GSS22JFMWW... • Answered on Feb 07, 2011
Doesn't sound like anything is
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.If your refrigerator is running but warm, then...Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...Refrigerator Condenser Coil Cleaning Refrigerator RepairRefrigerator Troubleshooting Refrigerator CompressorRefrigerator Compressor Start Capacitor and Start RelayRefrigerator or Freezer not Cooling or Getting Coldheatman101
9/29/2010 2:20:47 AM • GE GSS22JFMWW... • Answered on Sep 29, 2010
My refridgerator is not cooling but my freezer is.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
Water Running in efrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
8/19/2010 8:46:46 PM • GE GSS22JFMWW... • Answered on Aug 19, 2010
I have a GE refrigerator
Hi, answer a little bit long,will give you a link to for the problem.i bet you problem will be sovled.
(applianceaid.com/refrigerator.html).
Take care.
6/14/2010 4:19:01 PM • GE GSS22JFMWW... • Answered on Jun 14, 2010
Ice tray ftlls and never stops rotating then dumps
either u bar to shut off is bad, or the flap detectin ice level is in wrong position,..try this, in freazer turn of ice maker, count to 10while dong that move bottom hoizontal armrm back and forth 3 times, turn back on wiat 6 min, c if cycle statrs then
5/30/2010 9:43:48 AM • GE GSS22JFMWW... • Answered on May 30, 2010
Side by side GE PSW23PSTB SS. Freezer is 3 degrees
Check to see if evap fan is running. you can hear it if it is when you open the door of the freezer. Also check and see if there is a lot of frost on the back wall of the lower section of the freezer. If fan is running you have defrost problem. If not running it is a board problem. part # wr55x10942. If you have frost then it will more than likely be the defrost heaters which both are easy to do if you take your time.
1/31/2010 9:28:24 PM • GE GSS22JFMWW... • Answered on Jan 31, 2010
Freezer and cooler just doesn't seem to be getting cold.
Check the fan that pushes/pulls the air from the freezer to the refrigerator, if it is not working it will cause this type of problem. Good Luck, I hope this helped Please rate me, Thanks
1/5/2010 5:11:38 AM • GE GSS22JFMWW... • Answered on Jan 05, 2010
GE GSS22JFMWW Side by Side Refrigerator Logo
Popular Tags
58 questions posted
Top Refrigerators Experts
vince
Johnny 1000
View Most Popular
GE Refrigerators
  • GE Refrigerators
Most Popular Question
side side ge psw23pstb ss freezer 3
  • Refrigerators
