20 Most Recent GE Hotpoint 21.8 Cu. Ft. Top-Freezer Refrigerator Questions & Answers
HOTPOINT REFRIGERATOR RUNA ALL THE TIME COOLS POORLY
Yep, that is it. The heating element is open and/or the defrost timer is bogus. for parts go here. Search Over 2 1 Million Appliance Parts
9/9/2017 4:10:06 PM • GE Hotpoint 21.8... • Answered on Sep 09, 2017
Refrigerator Leveling Problem
Buy an inexpensive spirit level ( regular level sold everywhere) and check the level for yourself.. If you push/pull on the fridge..does it rock at all.. if so.. it may be level but the adjustable feet aren't making contact sufficiently to keep it from moving.. If after you've verified it is level.. you can do a few diagnostics on your own.. you can try removing everything on the door inside.. then listen for that noise.. if still there.. remove shelves and food etc.. see if it is still there.. check the snap on grill at the bottom to make sure it is secure.. check the hinges on the doors and make sure everything is snug.. make sure ther isn't anything on top of the fridge that might be vibrating when the fridge cycles.. You have many options here.. Hope this helps..
8/31/2008 2:05:59 PM • GE Hotpoint 21.8... • Answered on Aug 31, 2008
For a GE refrigerator model GFSF6KEX, how do you remove the ice tray? (Not the freezer drawer, just the tray.)
To remove the ice tray from your GE refrigerator model GFSF6KEX, follow these steps: Empty the Ice: Before removing the ice tray, empty it of any ice cubes. This will make it easier to handle. Locate the Ice Tray: The ice tray is typically located in the freezer compartment, usually near the ice dispenser or ice maker. Grasp the Bottom Edge: Stand in front of the freezer and open the door. Grasp the bottom edge of the ice tray on the sides. Be cautious not to place your fingers near the opening at the bottom front part of the bucket where the crusher blades are located. Lift Up the Front: Lift up on the front of the ice tray so that it clears the stops on the ice bucket rail. Pull the Tray Forward: Pull the ice tray forward and out of the freezer compartment. Reinstalling the Tray: To reinstall the ice tray, follow these steps: Line up the flange pieces on the sides of the tray with the channels in the ice bucket rails. As you push the ice tray all the way back, lift the front of the tray so that it clears the stops on the front of the ice bucket rails. Verify that the tray is properly inserted by pulling it forward. It should hit the stops on the rail and not come out. If it does, push the tray further back. Check for Misalignment: If you're unable to push the ice tray all the way back, it might be due to a misalignment between the back of the auger (located in the tray) and the prongs on the auger motor (mounted in the back freezer wall). To fix this: Remove the ice tray. Close the freezer door. Press the dispenser for cubed or crushed ice; you should hear a snap. Open the door again and reinstall the ice tray. Remember to handle the ice tray carefully, especially if it's full of ice.
3/31/2024 9:43:28 PM • GE Refrigerators • Answered on Mar 31, 2024
2answers
GE GNE27JYMFS Energy Star 27.0 Cu. Ft. French-Door Refrigerator. How long does the Sabbath mode last on a GE GNE27JYMFS please.
Question edited for a lot more clarity. Question moved from GE Ranges to GE Fridges. Sabbath Mode stays on until you turn it off. Press and hold the Lock and Light button simultaneously for 3 seconds to enter and exit the Sabbath Mode.
Bottom Freezer Refrigerator - Setting Sabbath Mode
GE Appliances https://products.geappliances.com > appliance > gea-supp...
Explanation of the Sabbath Mode Feature
GE Appliances https://products.geappliances.com > appliance > gea-su... Refrigerators with a Sabbath Mode feature puts the refrigerator in a timed defrost mode. It also turns off the icemaker, dispenser, and control touch screens. ..
1/16/2024 12:53:20 PM • GE Refrigerators • Answered on Jan 16, 2024
How do you replace the temperature control board on a ZICS360NRCLH. I don't see any screws or anything that is holding it up. Your assistance would be greatly appreciated thank you. Chuck
The Technical Service Manual says it is help by 3 magic slotted fasteners! Plus some RTV 102 seal which is this
Momentive RTV102 Adhesive/Sealant rtv 102, 2.8 fl oz ...
RSHughes https://www.rshughes.com > rtv102_white_3tg Momentive white RTV102 adhesive/sealant with a 72 hr cure time. Provides a 20 min fixture time. Delivers great performance with a shear strength of 200 psi, ... US$7.84 · ‎In stock Service Manual Page 24 https://www.manualslib.com/manual/739574/Ge-Zic36on-Series.html?page=24#manual //
12/29/2023 2:51:58 AM • GE Refrigerators • Answered on Dec 29, 2023
How do I install a filter for my GE Opal 01GENKT ice maker.
Question edited for clarity and toss in some CAPS. https://www.google.com/search?q=ge+ice+maker+model+opal01gepkt+filter+replacement I watched a video last night of a lady who took the side cover off and used a pipe brush to clean the black mold residue out of the pipes. I was pretty gross back there and she said it was only a year old. Check the side where the water connection is. https://www.youtube.com/results?search_query=clean+GE+ice+maker ..
12/27/2023 11:14:42 PM • GE Refrigerators • Answered on Dec 27, 2023
My GE fridge freezer not freezing after changing OEM parts
May be best to call the repairman.
12/13/2023 11:13:57 PM • GE Refrigerators • Answered on Dec 13, 2023
Why internal lights not working yet panel lights do?
There could be several reasons why the internal lights in a vehicle may not be working while the panel lights are functioning. Here are a few possible explanations:
1. Blown fuse: Check the fuse box to see if the fuse for the interior lights has blown. If it has, replace it with a new one of the same rating.
2. Faulty light switch: The switch that controls the interior lights may be faulty or worn out. Try toggling the switch on and off to see if it makes any difference. If not, consider replacing the switch.
3. Loose or corroded wiring: Inspect the wiring connections for the interior lights. Loose or corroded connections can disrupt the electrical flow and prevent the lights from working. Tighten any loose connections or clean off any corrosion.
4. Burnt-out bulbs: If all the interior lights are not working, it's possible that multiple bulbs have burnt out at the same time. Check the bulbs and replace any that are no longer functional.
5. Dimmer switch settings: Some vehicles have a dimmer switch that controls the brightness of the interior lights. Make sure the dimmer switch is not turned all the way down or set to a very low level.
If none of these solutions resolve the issue, it may be best to consult a professional mechanic or electrician to diagnose and repair the problem.
10/17/2023 4:59:01 PM • GE Refrigerators • Answered on Oct 17, 2023
I want to reset my GE Profile refrigerator's water filter light but have no water reset button. What do I do? Model GFE28GMKMES
https://products.geappliances.com/appliance/gea-support-search-content?contentId=22067 https://www.youtube.com/watch?v=LOYwkydARlY
9/29/2023 7:25:18 PM • GE Refrigerators • Answered on Sep 29, 2023
Why would a condenser fan run when the compressor isn't engaged on a GE side by side made in 1997 or so?
Possibly too hot and is cooling the condenser.
9/9/2023 7:41:04 PM • GE Refrigerators • Answered on Sep 09, 2023
Age of my Sears Kenmore Elite Refrigerator serial number 307KR00017.
March 2007 and the 17th produced that month. 03(month of)07 KR(range)(number)00017 (produced)
9/5/2023 12:49:50 AM • GE Refrigerators • Answered on Sep 05, 2023
Why is ice forming inside the door of GE manual defrost freezer?
your not going o see a light use a dollar bill or paper to test close door on paper should be unable to remove the paper go around the door testing --door my be in need of adjustments or hinge worn down
8/29/2023 9:51:07 PM • GE Refrigerators • Answered on Aug 29, 2023
Refrigerators Logo
3 questions posted
Top Refrigerators Experts
vince
Johnny 1000
View Most Popular
GE Refrigerators
  • GE Refrigerators
Most Popular Question
refrigerator leveling problem
  • Refrigerators
