Freezer wont freeze
if the back inside wall of the freezer doesn't have frost on it you don't have a defrost problem probably a bad computer board pull out the second bin or draw of food up from the bottom and stick your hand on the back inside wall of the freezerif there's no frost or like snow on the wall i would say you have a bad board,g.e. has been having problems with the boards,you can try calling them to see if they will help you out with the board,they might give it to you or give you a good deal on it part number WR55X10942 and it's around 150 dollars,pull out the fridge,look on the back wall and you'll see the board cover,unplug the machine,remove the cover,there are 4 plastic pins that holds the board in place,i use a pair of needlenose plyers,you pinch the tip of the pin and pull the corner of the board forwards,do this to all 4,you can check the board for burn marks but if you don't see anything it still most likely your problem,everything runs through the board,you'll see like j4 next to the wire connectors you can mark them or whatever is easy for you,pull them off and install them onto the new board,also if the machine is a few years old it's a good idea to remove the inside back wall of the freezer and on the top of the evap coil you'll see a sensor there,it looks like a white bullet with two white wires going to it,if where the wires connect to it has a black ring on it you should also change this out,the new temp. sensor is all white part number WR55X10025 and it's like 7 dollars,if yours already has it leave it alone.another thing i've noticed on some machines is the fans sound like they're running on half speed or going fast and then slow.hope this helps you out
