20 Most Recent
Emerson Cordless Bug Zapper Questions & Answers
Emptied clogged p-trap after using
hiya:) ok...First dry EVERYTHING up good then fill the sink(s) if you can. if you don't have stoppers then just run the water.then get under the sink.(close as possible) and look closely, using tissue in one hand to blot anything that you think mite be leaking, for the leak. i say this because i think you might be mistaken about the location of the leak as the disposal rarely leaks from the bottom. if it is then it is most likely severely damaged and should not be used, but this very unlikely and would probably also be plainly visible. so if you want to check it again i will be happy to help you further:)
7/27/2011 1:58:17 AM •
Emerson Home
Answered
on Jul 27, 2011
The in-sink erator did not
If this is a unit you have used within the last few days, it may be jammed. You will need to turn off the power to the unit; then examine it to locate & remove the obstructing item. If it is not easily seen and removed, you may need to remove the disposer unit from the sink and examine it more closely.
9/28/2010 4:31:13 AM •
Emerson Home
Answered
on Sep 28, 2010
Water leaking out the bottome of the disposal.
Check WHERE the water is coming from... tie paper towels around the fittings... at the top of the elbow that comes out of the side of the disposal and points down, just below the compression nut where the vertical part of the elbow enters the P-Trap, below the nut on the other side of the P-Trap, below the nut on the bottom of the elbow where the vertical part of the P-Trap goes horizontal. DRY off the bottom of the cabinet and put a dry paper towel down...
NOW, run the water, get a good flashlight and see exactly where the water is coming from (the paper towels tied around the pipes will help you see which compression fitting is leaking) if the water is not coming from one of the joints, and is coming from the actual disposer housing, that housing may be cracked and need to be replaced. Otherwise, if you can find the compression fitting that is loose and leaking, tighten it. If that doesn't work, you may need to replace the compression ring (plastic washer) which you can buy at any HW store.
10/11/2009 10:04:56 PM •
Emerson Home
Answered
on Oct 11, 2009
My dishwasher does not empty completely since I
There is a knock-out plug inside of the disposal port. A crewdriver, hammer and a few solid wacks should remove that completely.
If you already removed the plug, a piece may have been left in.
4/14/2009 4:20:33 PM •
Emerson Home
Answered
on Apr 14, 2009
What is a meat tenderizer?
This is used to tenderize meat before you cook it. It makes the meat easier to chew and digest. You can also use it before you boil or fry meat. You can do this mechanically, with something like a meat mallet that cuts up the meat fibres. You can do it thermally by putting the temperature really high to break down the connective tissue of the meat. The last method is enzymatic and uses enzymes to break down the collagen. This method is either slow with dry-aging the meat or you can use fruit to marinate the meat.
4/16/2024 6:28:01 AM •
Home
Answered
Yesterday
Lost half of my jets on one side of the tub only.I have tried closing the jets that do work half,does not make a difference to the jets not working.Would it be best to empty the tub and start over?
it's likely due to an air lock. Here's what you can do to resolve this issue:
Manually Clearing an Airlock:
Run the jets on low for about 30 seconds.
Then run the jets on high for another 30 seconds.
Repeat this process 3 or 4 times.
If you hear a gurgling sound and see air bubbling up, continue running your hot tub until it pushes all the air out.
If this doesn't work after several attempts, try a different approach.
Bleeder Valves or Pump Method:
Some spas have bleeder valves that allow you to bleed air out of the lines.
First, turn off the spa at the breaker.
Access the pump and loosen the valve to allow the air to escape.
When the air has bled out (you'll notice it turns from hissing air to a stream of water), close the valve.
Run the pump to ensure the jets are now pumping water as expected.
Why Are the Jets Not Working on One Side Only?:
Many hot tubs have two water pumps.
If the jets on only one side of your hot tub stop working, there could be an airlock in only one of the pumps.
It could also be a blockage in the jet lines for that side or a problem with the internal mechanism of the jet itself.
Can You Use a Spa with an Airlock?:
It is not recommended to use a hot tub with an airlock.
4/3/2024 4:33:08 AM •
Home
Answered
on Apr 03, 2024
Restarting my marcel hour strike quartz clock nrms603.
To restart your Marcel Hour Strike Quartz Clock NRMS603, follow these steps:
Stop the Pendulum: Gently stop the pendulum from swinging by holding it still.
Remove the Battery: Open the clock case and locate the battery compartment. Remove the existing battery.
Wait for a Minute: Leave the clock without a battery for about a minute to allow any residual charge to dissipate.
Insert a New Battery: Insert a fresh battery into the compartment, ensuring the correct polarity (usually marked on the battery holder).
Start the Pendulum: Gently release the pendulum and let it start swinging.
Set the Time: Use the clock's time-setting knob or buttons to adjust the time to the correct hour and minute.
Your clock should now be restarted and keeping time accurately
4/3/2024 4:30:05 AM •
Home
Answered
on Apr 03, 2024
My sloan flushmate toilet makes
this has already been answered on another site click here
http://www.landscapetutorials.com/tips/flushmate-noise.htm
the repair is done by
Fortunately this problem is very easy to cure. Simply follow the instructions below.
- Remove the ceramic cover from the tank on the back of the toilet.
- Fill a one-gallon jug with water.
- Pour the water into the toilet tank. Just pour it over the top of the black plastic Flushmate container. It will run down the sides into the bottom of the ceramic tank. See photo below.
- Now flush the toilet. The noise should be gone.
if you have any further questions please message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations in the future Thanks again Rick
3/14/2024 9:14:14 AM •
Home
Answered
on Mar 14, 2024
