GE Refrigerators • Uploaded on Sep 24, 2013
Try manual defrost reset
procedure: ----
First unplug the unit from main power outlet. Then empty whole unit completely.
Then keep both the doors open. Wait for 24 hours. All the ice collected on the
coils and in the freezer section will get melted. Clean the water
from the sections. Then Connect the power cord of the unit to main power outlet
after 24 hours/.Then set the temperature to normal in both fridge and freezer section.
It will take near to 4 hours to get run in its proper cooling cycle. Then check,
if the problem returns again. If the same problem occurs then it's defrost problem.
The defrost board and the defrost thermostat/heater is not functioning properly
and it has to be checked and replaced.
The defrost assembly
consists of three main parts. The defrost thermostat, the defrost heater and
defrost board. Any of the one is not functioning. When thermostat sense the
maximum cooling, it triggers the defrost heater to start heating and this
defrosts the ice collected on the coils and the system works. Both thermostat
and heater are controlled by defrost board. First the thermostat and
defrost heater to be checked, if both check ok by meter and visually, then its
defrost board causing the problem.
You can get required
parts from sears part direct online site or from repairclinic.com site.
This will help. Thanks. Helpmech.
71 questions posted
3,171 Questions
927 Questions
305 Questions
304 Questions
262 Questions
