20 Most Recent
GE GSS25IFR Side by Side Refrigerator Questions & Answers
Water is spraying from ice maker
This seems to be a popular problem. First I would unplug the fridge and plug it back in, sometimes it will reset the control and the solonoid for the water fill will stop.v if it does not stop that may be the water fill timer contacts are fused shut which means you need a new control board. I would also check the water basin for a float or water sensing probe. If they are dirty or damaged then it will not sense the water level and keep filling. I would also check the water fill valve to make sure it is not stuck open. If it is the board it might be easier to shut the water off and buy ice, they can be pricey.
Good luck
I have a 15 year
You need to unfreeze the drain at the back bottom of the freezer section. Pull out the bottom wire rack, and you'll see a small drain hole. Use a turkey baster and put hot water down it. If you have the manual, it has instructions.
